Thread: ECU replacement following remap
    Regular Member Mark's Avatar
    Daventry
    Default ECU replacement following remap
    My car had a remap six months ago, recent problems occured requiring a new ECU to be fitted. The remap is off now and car back to standard, should I risk having the map put back on?
    Is there anyway the remap could be respnsible for breaking the ECU?
    Thanks for any advice
    http://forum.vectra-c.com/images/smilies/smile.gif
    [Ex]Admin Duncan's Avatar
    Which remap? What exactly was the problem? A remap can goose an ECU but you'd usually experience the problem there and then, not several months down the line.
    Some more info may help to give a better answer.
    Regular Member Ben H's Avatar
    Herts\Beds Border
    I've recently had a fault which said to replace or repogram my engine control module. £40 later with new software fixed the problem a treat.
    There was no reason or cause to why this happened.
    Daventry
    Hi Duncan
    Thanks for the reply.
    It was a Superchips remap.
    M
    Daventry
    Quote Originally Posted by Ben H View Post
    Hi Ben H
    Is your car standard or remapped?
    morton
    i've had lots of my previous cars chipped and never had a problem ! it would surprise me if that is whats caused your issues?!
    Herts\Beds Border
    Quote Originally Posted by Mark View Post
    Hi Ben H
    Sorry, my car was standard but was just saying how for no reason one day the software of my ECM decided to be corrupt and strangely the fault/performance deteriated over a couple of weeks then one day it had updated software loaded back on and it was fixed.
    What I was getting at was the possibility yours was either knackered or just needing a reprogram.
    Daventry
    Hi veccy22
    Thanks for your input - but do you think a remap could be the cause of the ECU faults over time. Can increased power cause stress on the components or programme.
    M
    A remap won't gradually cause ECU faults over time - all a remap is is a bunch of different settings/variables. Increased power may cause more wear on mechanical components, but not an ECU - it's all electronic.
    If a remap is going to cause a problem with an ECU it will more than likely be as it's being flashed, not some months down the line.
    HTH
  1. Replies: 15
    Last Post: 27th September 2013, 00:22
  2. MAS cant remap car :(
    By mtqn in forum Diesel Engine related
    Last Post: 12th August 2012, 12:49
  3. 2.0t remap from remap science bradford
    By stefan7153 in forum Petrol Engine related
    Last Post: 4th May 2011, 22:03
  4. Remap replacement
    By spooney in forum Petrol Engine related
    Last Post: 9th March 2010, 23:49
  5. Remap SRi 150?
    By antowns in forum North East RO Vacant - ARO - Vacant
    Last Post: 22nd December 2009, 23:26
