Thread: front window limit switch?
    Regular Member kgsric's Avatar
    Northants
    confused front window limit switch?
    this problem has been discussed several times but still have fault (& hoping its not the motor) anyway. drivers window goes down gradually & fully down when you press switch BUT only usually goes up gradually (have to keep pressing button) & doesnt go up on key fob.
    when the window is closed & u keep your finger on the button you can hear the motor turning (as if the glass is going to shatter) & it doent stop like my passenger side does.
    is there a limit switch you can reset as i think it goes up gradually as it doesnt know where it is? any ideas?? cheers all
    Full Member Big Sig's Avatar
    Push both front window buttons down until they reach the bottom - hold the switched until they stop. Then do the same to close them. This should reset the limits on the windows.
    Northants
    i tried that a couple of times it worked, then i took key out of ignition put back in & it went back to normal
    Regular Member Ashtoroth's Avatar
    Have you tried taking battery off for 30+ mins to reset stored info in ecu ?
    Northants
    no i haven't, im a bit dubiouse about disconnecting the battery incase something goes wrong when i reconnect it, i might give it a go
    if it's a standard car that hasn't had anything funny with the electrics done to it, then resetting the ECu's will be painless....
    Northants
    funny as in...? iv fitted a rear camera to the reverse light, would that cause a problem? i dont think anything else has been done
  1. Free: Free Front drivers window switch.....
    By Sebastian in forum Parts for sale
    Last Post: 4th November 2012, 21:11
  2. N/S front window switch
    By byebyeitsagsi in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2009, 11:52
