Results 1 to 10 of 11
Thread: Vxs new Parking sensor kit. x-vision.
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Default Vxs new Parking sensor kit. x-vision.
    Popped into the local Dealer this week and saw they have a new kit supplied by X vision Parking Systems....£300 fitted
    Had a look on the net for info on them but no joy. Any one know of these?
    Regular Member um20's Avatar
    Mar 2007
    Doncaster
    Same as these?
    http://www.sccuk.net/xvision.php
    Quick google returned that, not sure if it is the same if you've already searched in vain.
    Feb 2006
    Wirral
    Thats them...I spent hours on google etc today....
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Brocks,
    You can get the proper Bosch kit for less than that from your Dealer. Then it will intergrate with canbus and you will be able to switch it from the button on the dash.
    Paul.
    Regular Member fields's Avatar
    Mar 2007
    Lincoln
    Got a cheap set of ebay less than £30 and they work fine. Make a nice beeping sound when you get within 2 meters, just what I wanted as I must admit that when I first got the "C" a number of times I parked and after I got out had to get back in and reverse a bit more, just could not tell where the back end was. I know it needs washing
    Regular Member wardy's Avatar
    Chichester
    Quote Originally Posted by fields View Post
    Were they easy to fit, and where did you get them from ?
    Mar 2007
    Lincoln
    Got it off ebay item #(#250136050947) £15.99 then followed the instructions,easy to fit, you do need a relay though so the bulb failure system still works ok. Plus some paint and laquer. Take your time measure a couple of times before drilling. Didn't even take the bumper off, put plenty of masking tape where you mark it to drill then no prob.
    Jun 2007
    leeds
    quick question,is it ok to spray these,doesn it effect the sensor?
    Mar 2007
    Lincoln
    It is fine to paint then. just degrease and a gentle rub with fine emery. Spray with plastic primer a couple of coats. Then the colour you want, again a few coats drying in between. Finally a couple of coats of clear laquer. No effect on the sensors at all.
    Feb 2006
    Wirral
    Quote Originally Posted by leeds vectra View Post
    Brocks,
    Paul.
    Paul,
    How much and whats the part numbers? What button in the dash?
  1. Parking sensor
    By CHooper80 in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2010, 14:00
  2. x vision parking sensors
    By trucker in forum Insignia car chat
    Last Post: 9th June 2010, 08:37
  3. Rear Parking Sensors - £135 X-Vision Fitted
    By mickyd98 in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2008, 19:23
