Thread: Belts?
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Default Belts?
    Guy's,
    Would someone be as so kind to pass on their vast knowledge (lick lick) to provide a mileage guide on the changing of all belts.
    I'm soo clueless that I thought the only belt's need changing are the timing and fan belts @ every 60k or so depending on engine size, yet what about the cambelt etc?
    Much appreciated.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Timing belt is cam belt.
    Can't think of any other belts, cam belt (timing belt), auxiliary drive belts (alternator, aircon etc)
    on your 1800...timing belt should be done around 40,000 to be safe
    the auxilary should go to around 80,000 but check it when you do the cambelt for cracking in the vee ridges..
    Mar 2007
    NI
    Quote Originally Posted by Ste View Post
    I'm a numpty head.....
    Mar 2007
    NI
    Mark, auxilary belt??? is this more expensive to replace or would it be better to change both at the same time. Mines coming to 70k and I was gonna do both then. Was also thinking of chaning the water pump and the fan belt in one swoop? Would this be advisable for peace of mind???
    (Many thanks!)
    Quote Originally Posted by Stevie-B View Post
    (Many thanks!)
    Get the cam belt kit - rollers and tensioners - done with the water pump, approx £220 from your local dealer. The AUx belt drives the air con and alternator. There is no fan belt as its an electric fan. The Aux belt is only about £10 I seem to remember. On the Z18xe anyway.
    Mar 2007
    NI
    Thanks matey... me thinks I need to get a haynes manual before asking silly questions.
  1. Cam belts
    By SRIRob in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 23:01
  2. Anyone changed the belts on a 1.8 vvt?
    By PeterVV in forum Engine & Drivetrain
    Last Post: 9th December 2009, 19:04
  3. belts/tensioners??
    By briancdti in forum Engine & Drivetrain
    Last Post: 1st November 2009, 18:52
  4. Belts
    By bgm46 in forum General Chat
    Last Post: 29th January 2009, 09:56
  5. Belts
    By jamesr in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2008, 23:02
