How easy is it to change a Gearknob on the Vectra??
Are they just twist off, or are they held on by a grub screw?
Any help really appreciated.
they are shrunk on..you need to split the old one off with a hacksaw and a cold chisel....
Get your 5 year old niece to sit in the car for 5 minutes. Comes off in their hands.
Worked a treat in my old Mondeo...
Correction, it wasn't the Mondeo, it was a Pug 306 I had for a few weeks.
i found a stick of dynamite to be the most effective method!
Andyvec got mine off in seconds - facelift (not sure if it is different).
He wrapped a cloth around the gear knob, applied even pressure with a good set of grips and then hit the grips with a hammer from below - worked a treat.
Other will tell you that the only way is to cut it off with a hacksaw - Andy proved different!!
Got Mine Off With A Hammer And Chisel Two Blows And It Was Off
i done mine theres a how to do thread on hear for great advice took me about 10mins to do just need a hacksaw and a bad day a work that works wounders ..............
