Thread: Gearknob's
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Default Gearknob's
    How easy is it to change a Gearknob on the Vectra??
    Are they just twist off, or are they held on by a grub screw?
    Any help really appreciated.
    they are shrunk on..you need to split the old one off with a hacksaw and a cold chisel....
    Feb 2006
    Guttedsville
    Get your 5 year old niece to sit in the car for 5 minutes. Comes off in their hands.
    Worked a treat in my old Mondeo...
    Correction, it wasn't the Mondeo, it was a Pug 306 I had for a few weeks.
    Regular Member storey_3000's Avatar
    May 2006
    somerset
    i found a stick of dynamite to be the most effective method!
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Andyvec got mine off in seconds - facelift (not sure if it is different).
    He wrapped a cloth around the gear knob, applied even pressure with a good set of grips and then hit the grips with a hammer from below - worked a treat.
    Other will tell you that the only way is to cut it off with a hacksaw - Andy proved different!!
    Regular Member vectrahunter's Avatar
    Feb 2007
    crosshouse
    Got Mine Off With A Hammer And Chisel Two Blows And It Was Off
    Quote Originally Posted by Neil View Post
    Yep, no need to hack the knob to pieces, just whack it from underneath.
    Regular Member nph1's Avatar
    cheltenham/gloucestershire
    Default gear knob changed
    i done mine theres a how to do thread on hear for great advice took me about 10mins to do just need a hacksaw and a bad day a work that works wounders ..............
