Any idea why my rear water squirty isnt coming out?
I can hear the pump working and I also disconnected the pipe to the nozzles and nothing came out.
Where is the rear washer motor and how easy is it to clean the filter for it (If it has one)
do the others work??
Fronts do yes,
get a pin and stick it in your jet holes and see if that works. mine had some s**t in mine works fine now try that and get back to me
I took the pipe off that goes into the washer jets and no water came out.
hmmm there ent no water leaking from anywere is there?? maybe off at the pump
It was raining so couldnt tell.
Are there 2 pumps on the washer bottle?
Front and rear work from the same pump (front of passenger side wheel arch)
Check to see if water is coming from there
ent sure on that m8 honest i ent think it just 1 put dono and its to dark to go looking put iv never looked that far in to it sorry m8 id of sed it a filter blocked or ya pipes blocked ill get the car in the garage and have a look quick
How does it decide where the water goes if there is only 1 pump?
