Results 1 to 3 of 3
Thread: TB problems
    Regular Member SRI-150's Avatar
    Jun 2007
    Cheshire
    confused TB problems
    hi all, jus got my t-tuning box today, and its amazing , the only 2 problems are its a bit smokey but will be better with me BMC and airbox mod which hopefully should cum 2mora, and the other is when i started it before the engine management light came on and then went off when i started up, i thinki've seen this on here, is it a usual side effect of the box
    thanks everyone
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    It sounds like you've got it turned up too high. The management light coming on then going off when the engine starts just indicates you've had a problem recently - within the last 25 starts IIRC - it should reset itself in due course
    Jun 2007
    Cheshire
    wel it isn't adjusatble so it may be set too high i drove behind it 2day when someone else drove it an its only a bit of smoke but it should run better with the air filter, i haven't had the light come on yet whilst driving so touch wood it wont, only on start up, thanks
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
