Results 1 to 10 of 11
Thread: -45mm pi springs
    Regular Member hagga's Avatar
    kingswinford
    Default -45mm pi springs
    just a quick question...just about to order some pi springs(-45mm pn 60-274) but a few sites say the should be fitted with shortened shocks...anyone had any experience with these..can i get away with the std dampers?
    Regular Member Damian's Avatar
    Market Drayton
    I am sure Mark (GSI3.2) will be along soon, but am pretty sure the answer is no.
    Even on the SRi which is already lower than the rest of the range you still need to change them for -45mm springs.
    If you change the springs in my opinion you should change the shocks also. I changed my springs and a few months later one of my rear shocks blew. It might be coincidence or it was it's time due to my high mileage but I changed all 4 shocks to Eibach ones to match my 30mm Eibach springs.
    Regular Member lee_eardley's Avatar
    Back to waddington,Lincoln)
    think that you can use standard shocks up to 40mm lower, and any thing more than this then the shocks need changing
    from pI web site
    PI Spring Features
    Springs which are matched to your car
    Bright red springs
    Retains good ride quality
    Sports look transforms the appearance of any car
    Note:
    In Stock
    It is recommended that shortened shock absorbers are used with these kits.
    Here, there and every where!
    Yup, if you are going to lower by -45mm then new shocks it is
    SOMERSET
    Quote Originally Posted by Caterman View Post
    Disagree with the above.
    They ADVISE to go for shorten shock's but it's not a problem if you don't.
    I have had 45mm pi spring's fitted and so has Payne and KevA and we have the original shock's on and have no problems at all.
    You go for it, you will love it......
    kingswinford
    Quote Originally Posted by PIMM View Post
    great stuff...i'm off to order them ..just gotta pray for good weather next weekend...gonna be busy as I wanna laquer my calipers, fit uprated discs and fit my new grill too hmmm...i just thought..I was happy with my car n rich before I came on this site...look what u lot have done to me lmao cheers guys
    SOMERSET
    Do not forget the pictures
    kingswinford
    I knew that was coming haha
    Sunny Aberdeen
    Ditto .........
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    I don't have PI springs mate
  1. PI springs 45mm or 30mm
    By TimTay in forum Handling & Braking
    Last Post: 30th November 2010, 20:50
  2. Pi 45mm springs
    By Fig-sri in forum Suspension, Wheels & Brakes
    Last Post: 12th July 2010, 11:08
  3. Anyone used 45mm Supersport springs.
    By Hyperhart in forum Handling & Braking
    Last Post: 17th May 2010, 19:11
  4. SuperSport -45mm springs
    By damian s in forum Parts for sale
    Last Post: 9th December 2009, 23:25
