Results 1 to 10 of 26
Thread: not sure if my new tyres are.......
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default not sure if my new tyres are.......
    the best for my car.......
    I was travelling down the a14 and yes its rutted but i thought the rear axle was about to overtake the front.
    the old tyres were michelin pilot primacy with 1.6mm of tread on them
    the new tyres are toyo proxes t1-r's with about 7mm.
    both have the same spec - 215/55 16zr 93w, but the new ones make the car feel like its got a weave on......
    is it because they are new or is it something else.
    thanks if you can help.
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    Quote Originally Posted by Judas View Post
    ......but the new ones make the car feel like its got a weave on......
    do you mean its snaking slighty??
    Suffolk
    Quote Originally Posted by neilshaw1980 View Post
    yes - just that.
    what is it........?
    Do you have all four tyres the same or are you progressively replacing (ie different brand front/rear)?
    Have you re-checked tyre pressures cold?
    Suffolk
    the front two are kuhmo - same size - same weight, everything.
    always check the pressures cold and with a digi temp gauge
    it could be the blocks are squdeging due to their height.
    Although the front two are the same size and ratios, how do they compare front/rear on :
    treadwear / traction / temperature
    It could be the fronts are warm, but the rears are still cold, which could cause oversteer on severe corners
    Very unlikely, but is possible
    Suffolk
    the front is a 360 - A - A and the back is a 280 - AA - A.
    the tyres were up to temp - its weird...........
    It looks like this could be from having hard compound tyres on the front and hard compound tyres on the rear, giving the treadwear ratios
    Really, they should be within 40 units of each other
    Oct 2006
    coventry
    how about trying the toyo's on the front and the khumo's on the back. Dont know if it would help but its worth a try.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Could also be the new tyres aren't scrubbed in,they need up to 200 miles to do this.
  3. More tyres....!
