Thread: Dimmer Control wire again
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Default Dimmer Control wire again
    The lighing lead in the cig lighter doesn’t seem to have any signal going to it, maybe because there no light on the socket – is there another easily accessable lead I can use to dim my Alpine HU
    Regular Member Ben H's Avatar
    Herts\Beds Border
    I wired my Alpine up to the illumination wire at the head unit & that did sqwat all from there.
    You got to watch, come to think of it my illumination is lowered and you don't get a full 12v for the hed unit to detect the illuminaton is on. Try turn it up to max & see if it works then. I'll have to try also.
    You really need to source a 12v illumination from the back of the headlight switch but don't know if the Vectra head light switch would work like this being Canbus.
    Mar 2007
    Southport
    The headlight switch is fed by very fine wires which I'm guessing are low just voltage triggers. As you say I need one that gives me a full 12v feed
    Regular Member stickshift's Avatar
    North London
    Quote Originally Posted by Ian S100 View Post
    I think they work via can bus, so be careful that you don't fry anything!
    Herts\Beds Border
    New Audis are the same and you can find a suitable 12v illumination there. It's not going to draw any current, it just needs to sense it.
    Mar 2007
    Southport
    Can the power to the cig lighter illumination be switched on via Tech 2 - is it intended to supply a reg bulb on an LED & carries a low voltage. I can't find my megga so can't test it for a low voltage only know it doesn't carry 12v
  1. One dipped beam dimmer than the other...
    By y2joeyb in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 15:45
  2. Bulb gone on the dimmer thingy
    By Sean-2.2Direct in forum Bodywork & Interior
    Last Post: 24th August 2009, 23:08
  3. Anybody Know Were The Dimmer Control Wire is ?
    By tonywolst07 in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2007, 12:34
  4. Headlight/Fog light/Dimmer Cluster....
    By BigMan in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2007, 08:23
  5. Where's The Dimmer Control Wire ?
    By Cruachan in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2006, 23:36
