Thread: rear screen washer trouble
    Regular Member dezzie's Avatar
    May 2006
    blackpool
    Default rear screen washer trouble
    as above, only a tiny trickle of water is coming out of the rear screen washer jet the fronts are ok, have tried a pin in the hole but still doesn't come out any ideas could the tube have come off somewhere?
    Regular Member storey_3000's Avatar
    May 2006
    somerset
    Can the hose get trapped when shutting the boot any where? Or is it routed so it kinks when you pull the lid down?
    Up Norf
    they used to split at where it bends by the hinge and run inside the car
    Regular Member stickshift's Avatar
    North London
    If it's a vectra hatch that you have and the hose was split/disconnected you should see water inside the car accompanied by a damp headlining. It may possibly be a clogged pump intake on the bottle, you can pull it off the bottle and give it a clean. It's held in by a rubber grommet.
  1. Rear screen washer problem
    By steveyd83 in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2011, 21:21
  2. Rear Screen Washer Issue
    By Kev_G in forum Bodywork & Interior
    Last Post: 21st March 2011, 00:39
  3. Screen washer help pls
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2011, 15:24
  4. Screen washer problem - Please help
    By MattW74 in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2010, 12:04
  5. screen washer pump
    By simon1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2008, 16:40
