Results 1 to 10 of 14
Thread: Rear tyre wear Vecta 03
    Jun 2007
    Basingstoke
    Default Rear tyre wear Vecta 03
    Can anyone help?
    I have an 03 Vectra hatchback and the rear tyres wear out on the inside. Two tyre fitting places have suggested it may be due to carrying heavy loads. The heaviest thing the car carries is me, cheecky devils. The wheels were aligned when the rear tyres were replaced 6 months ago.
    Regards
    Gordonc
    The car needs to go up on a ramp and have the rear bushes checked
    Have the rear tyres always been on the rear, or swapped at any point?
    How many miles is on them (front / rear)?
    Jun 2007
    Basingstoke
    Hi m8internet
    The car has done 53k but the tyres have only done about 4k.
    Regards
    gordonc
    Have there been any modifications or new parts fitted to the rear suspension?
    4,000 miles is almost nothing to rear tyres
    What make, brand, and type?
    I'd be taking them back to where I bought them and asking serious questions!
    My rear tyres have already done 10K miles in 4 months, and are down just 2mm
    Regular Member simac's Avatar
    Wirral
    Yeah, doesn't sound right. My 03 has done just about 58k miles and have just put it's third rear set on, and that was because of punctures.
    Jun 2007
    Basingstoke
    No mods or replacement parts and they were Avon, £100 each fitted at National
    As above, get the car up on a ramp and check those rear bushes
    Was a full four wheel alignment check dones with the new tyres?
    If not, it really should be done at every new tyre fitting
    National Tyres check for FREE, and charge just £11 if adjustment is required at the time of fitting
    Take your receipt, and give them a musolobo
    Jun 2007
    Basingstoke
    Will do, thanks
    morton
    when i lowered my previous C i did'nt realise it had camber adjustment ! ripped the rear tyres off in less than 4k from brand new ! so if the bushes are ok get the camber checked aswell !
    Regular Member aos's Avatar
    Stirling
    my 03 has a similar wear on the inside of the rear tyres(10k). It also has wear on the outside of the fronts. However, my springs have just been replaced on the front, so that does explain some of it. My local garage checked everything out for me, and said apart from the springs, it was ok. Passed the M.O.T. at the time.
    I'm gonna wear out the tyres, then fit a new set of boots and get tracking etc checked then.
  1. Rear passenger inner tyre wear
    By iam2103 in forum Suspension, Wheels & Brakes
    Last Post: 1st July 2012, 21:19
  2. uneven tyre wear on rear
    By croado in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2011, 19:12
  3. Rear tyre wear
    By Geoff644NI in forum Suspension, Wheels & Brakes
    Last Post: 29th March 2011, 22:00
  4. Rear Tyre Wear
    By johnmac in forum Suspension, Wheels & Brakes
    Last Post: 28th June 2008, 22:20
  5. Rear tyre wear
    By nhoj in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2008, 15:10
