Results 1 to 10 of 11
Thread: Bluetooth Unit - what to buy, where to get fitted etc.
    Jun 2007
    Essex
    Default Bluetooth Unit - what to buy, where to get fitted etc.
    Hi,
    I am looking for a bluetooth unit for my Vectra - CD70 Sat Nav.
    I would need to get it fitted, as I wouldn't have a clue LOL
    So a) could do with a recomendation b) suggestion on where to get it fitted (I am in Essex, but travel widely throughout the UK)
    And also whereabout is it fitted in the car - does anyone have any photos?
    many thanks.
    function __RP_Callback_Helper(str, strCallbackEvent, splitSize, func){var event = null;if (strCallbackEvent){event = document.createEvent('Events');event.initEvent(str CallbackEvent, true, true);}if (str && str.length > 0){var splitList = str.split('|');var strCompare = str;if (splitList.length == splitSize)strCompare = splitList[splitSize-1];var pluginList = document.plugins;for (var count = 0; count < pluginList.length; count++){var sSrc = '';if (pluginList[count] && pluginList[count].src)sSrc = pluginList[count].src;if (strCompare.length >= sSrc.length){if (strCompare.indexOf(sSrc) != -1){func(str, count, pluginList, splitList);break;}}}}if (strCallbackEvent)document.body.dispatchEvent(even t);}function __RP_Coord_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Coord_Callback = str;pluginList[index].__RP_Coord_Callback_Left = splitList[0];pluginList[index].__RP_Coord_Callback_Top = splitList[1];pluginList[index].__RP_Coord_Callback_Right = splitList[2];pluginList[index].__RP_Coord_Callback_Bottom = splitList[3];};__RP_Callback_Helper(str, 'rp-js-coord-callback', 5, func);}function __RP_Url_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Url_Callback = str;pluginList[index].__RP_Url_Callback_Vid = splitList[0];pluginList[index].__RP_Url_Callback_Parent = splitList[1];};__RP_Callback_Helper(str, 'rp-js-url-callback', 3, func);}function __RP_TotalBytes_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_TotalBytes_Callback = str;pluginList[index].__RP_TotalBytes_Callback_Bytes = splitList[0];};__RP_Callback_Helper(str, null, 2, func);}function __RP_Connection_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Connection_Callback = str;pluginList[index].__RP_Connection_Callback_Url = splitList[0];};__RP_Callback_Helper(str, null, 2, func);}
    Up Norf
    parrot kits are good.
    As for fitting there is a pre-wired cable behind the glove box, just plugs straight in!
    Cirencester
    the parrots wont plug straight in to the factory loom, the parrots come with ISO plugs, if you want to plug it in to the cd70 you need remove the mute box part of the loom and leave just the blue (mute) and line out Brown/Green +/-coming out from the block from the blue box.
    Insert the blue lead into the spare slot in the Quadlock next to the thick red power cable and use the diagram on top of the CD70 to locate the line in on the HU.
    P.S doing it this way saves loads of room behind (there is very little)
    also you will need to pick up the ignitiion switched supply from the fag socket.
    Wiring it in to the HU this way mutes the stereo and will puase the CD/MP3 when you get a call and you also can control the volume from the steering wheel to
    PM if you need anymore help
    HTH
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Got the Parrot 3200 - can highly recommend it
    Cirencester
    Pm Sent!!!
    Up Norf
    no your right you need to get a saab vda-parrot adaptor lead from sio-communications then it plugs straight in no need to even take the radio out.
    You can then discard the mute box and don't need to modify anything.
    Thats how i did mine.
    Jun 2007
    Essex
    Thanks.
    Does it clip on to the vents or is it mounted elsewhere?
    Feb 2006
    Dorset
    Quote Originally Posted by armstma1 View Post
    Not all of them have the VDA socket and fme lead behind the glovebox, infact on the facelift its onlt there if you ask for it as an option
    ive got cd40 opera in my car and no VDA plug another engineer has a pre facelift with the opera unit and has the input .
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Parrot all the way mate 20 minutes to install and never looked back!
    Cirencester
    The screen/control pad can go where ever you want it to. afixes using very strong sticky pads, comes with about 5 different types of mount
    ill get a picture of mine in a bit
    HTH
  1. Which Double DIN Bluetooth head unit?
    By Padster72 in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2010, 17:13
  2. Pioneer dvd sat nav bluetooth double din unit
    By lochgilp in forum Parts for sale
    Last Post: 24th March 2009, 21:08
  3. Fantastic Kenwood dvd double din bluetooth unit
    By lochgilp in forum General items for sale
    Last Post: 20th May 2008, 18:24
  4. Bluetooth OBD-2 unit
    By Big-Pete in forum Tuning
    Last Post: 30th July 2007, 21:04
