Thread: CD70 - sound level on Sat Nav
    Jun 2007
    Essex
    Default CD70 - sound level on Sat Nav
    Hi,
    Is there any way to alter the sound level on the Sat Nav on the CD70?
    I can only really here mine, when I have my window closed and the radio turned down.
    if I have the radio on then, I can't here the directions having to rely upon looking at the screen, which half defeats the object.
    Thanks.
    function __RP_Callback_Helper(str, strCallbackEvent, splitSize, func){var event = null;if (strCallbackEvent){event = document.createEvent('Events');event.initEvent(str CallbackEvent, true, true);}if (str && str.length > 0){var splitList = str.split('|');var strCompare = str;if (splitList.length == splitSize)strCompare = splitList[splitSize-1];var pluginList = document.plugins;for (var count = 0; count < pluginList.length; count++){var sSrc = '';if (pluginList[count] && pluginList[count].src)sSrc = pluginList[count].src;if (strCompare.length >= sSrc.length){if (strCompare.indexOf(sSrc) != -1){func(str, count, pluginList, splitList);break;}}}}if (strCallbackEvent)document.body.dispatchEvent(even t);}function __RP_Coord_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Coord_Callback = str;pluginList[index].__RP_Coord_Callback_Left = splitList[0];pluginList[index].__RP_Coord_Callback_Top = splitList[1];pluginList[index].__RP_Coord_Callback_Right = splitList[2];pluginList[index].__RP_Coord_Callback_Bottom = splitList[3];};__RP_Callback_Helper(str, 'rp-js-coord-callback', 5, func);}function __RP_Url_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Url_Callback = str;pluginList[index].__RP_Url_Callback_Vid = splitList[0];pluginList[index].__RP_Url_Callback_Parent = splitList[1];};__RP_Callback_Helper(str, 'rp-js-url-callback', 3, func);}function __RP_TotalBytes_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_TotalBytes_Callback = str;pluginList[index].__RP_TotalBytes_Callback_Bytes = splitList[0];};__RP_Callback_Helper(str, null, 2, func);}function __RP_Connection_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Connection_Callback = str;pluginList[index].__RP_Connection_Callback_Url = splitList[0];};__RP_Callback_Helper(str, null, 2, func);}
    Nicking Ya Dinner.
    Should be a setting that is accessed by the central dial on the unit in options tbh, not had one myself so I can't direct you all the way in, HB should show you how. hth.
    Jun 2007
    Essex
    Thanks - I have looked in various menus and can't see anything that relates to the sound for the Sat Nav.
    I would have thought it would lower the volume in the radio/CD etc., but it doesn't. This is the logical method.
    Nicking Ya Dinner.
    Have you tried the menu with the sat nav running yet?
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    During navigation, press settings button, select "Navi message" (or something like that);
    or with Main screen, press settings button, select Volumes, select "Navi message"
    Jun 2007
    Essex
    Thanks - I tried altering when on a 6 hour drive the other day - will try again
    Thanks.
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Correction
    or: select audio, press settings button, select Volumes, select "Navi message"
    or: press settings button, press audio button, select Volumes, select "Navi message"
    Leicester
    If you have not done it, I'll post up a how to to help you, but it can be done.
    Preston Area
    Quote Originally Posted by sig63 View Post
    Correction
    i'm pretty sure its the 2nd option...whilst in nav mode - ->audio -> settings and youll see it in there..
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by bruceybonus View Post
    no they work all three...
  1. Oil level gsi .
    By peter-gsi in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 15:52
  2. CD70 NAVI No Sound - Squealing Noise
    By mattr in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2008, 18:47
  3. oil level........
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2008, 21:27
  4. CD70 sound problems
    By ballmonkey in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2007, 18:48
  5. sound equalizer on CD70 ?
    By Top banana in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2006, 22:47
