Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Tyre Question - Extra Load and Reinforced
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Default Tyre Question - Extra Load and Reinforced
    Just looking on blackcircles.com and it has some tyres as Extra Load and some as Reinforced. Are they the same thing? Would they both be ok on my 3.0?
    Cheers.
    Andy
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Andy,
    I thought they were on and the same, different manufactuers using different terminology, unless someone knows different.
    Wilts
    I just rang blackcircles.com and they said for the 3.0, as long as a tyre is 94W or higher then its the correct load rating. The annoying thing is they dont put the load rating (number bit) on the website. They only put the letter (speed rating).
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Unfortunately they can mean the same or different depending on the manufacturer and or the type of tyre!,as has been said go by load rating number not a description.
    Warwick
    The term extra load usually refers to a tyre with a higher load index where the the same size tyre is available with a lower load index.
    The normal size fitted is 215/50 R 17 and for the 4 cylinder engine models has a load rating / speed index of 91W whereas the 6 cylinder diesel is a 95W.
    I use Pirelli P Zero Nero with a 95Y rating. The alternative 18'' tyres are not available with 95W and are normally 94W.
    Reinforced means that the tyre has extra plies (often 6 or 8 instead of the usual 4)and is used by vans, trailers and caravans etc but not cars.
    Up Norf
    nope! a car tyre has either ONE or TWO plies NEVER 6 or 8 like you've stated.
    The difference is in the TYPE of ply used i.e. more cords per inch and the thickness of these cords.
    Warwick
    Did you read the last line of my posting?
    I said that 6 and 8 ply tyres are used on vans, trailers and caravans but not cars!
    Up Norf
    i did and you said "Reinforced means that the tyre has extra plies" i was simply saying that's not the case on cars.
    In fact only large goods vehicles have so many plies, HGV plies are made from steel.
    Up Norf
    ps you did say "the usual 4" too lol
    I think you will also find a 91W is the lower limit on 215/50/17's for a v6 diesel. If I could afford it I would always go for EL or Rienforced tyres. I mean, why not!
  1. Tyre load rating
    By Threepiers in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2012, 21:18
  2. Tyre load ratings.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2010, 00:22
  3. Michelin Pilot Sport 2 (Extra Load)
    By trucker in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2007, 20:00
  4. Extra load tyres
    By Ian T in forum Comedy & Humour
    Last Post: 1st March 2007, 09:22
  5. Toyo T1-R Extra Load?
    By ukanalyst in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2006, 14:48
