Thread: Rear Suspension problems?
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Default Rear Suspension problems?
    Has anyone else had any problems with the rear suspension.
    Every time i hit a decent size bump, the nearside rear corner seems to viabrate violently for about 2/3 seconds.
    Any ideas??
    I have checked all the bushes and they all seem ok to me, tyre pressures, bearings etc, and it all seem in order.
    Someone suggested the shock absorber is knackered, but i dont want to go replacing it unless i'm sure thats the problem(if it turns out it is the problem, i'll replace the whole suspension and lower it)
    It will be the shock not damping the spring. A common weak failure point on the vec's and siggys
    Jun 2007
    Thought that might be the case, but wanted someone else's opinion too.
    Might be time to slam it on the floor while replacig the shocks.
    if you drop it round i'll whip it off and tell you if it's shot or not.....but it's classic symptoms..
    Jun 2007
    Cheers Mate, i may well take you up on that offer.
    one evening next week any good to you, as i've got folks coming this weekend?..it'll only take about 15mins....
    Jun 2007
    Just let me know which evening, i'm off work at the moment so i can do anytime
    Cheers once again.
  1. vectra c suspension problems .
    By jonbav in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2012, 20:48
  2. FK Coilovers suspension problems
    By craig20102010 in forum Suspension, Wheels & Brakes
    Last Post: 29th November 2012, 23:03
  3. Suspension problems!
    By Matt_Bankier in forum Suspension, Wheels & Brakes
    Last Post: 13th April 2012, 19:42
  4. Suspension problems...part numbers
    By n8sby in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2011, 13:02
  5. Rear suspension
    By nhoj in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2008, 15:05
