Thread: No holes phone bracket for Vec-C/Signum
    Regular Member muffking's Avatar
    Default No holes phone bracket for Vec-C/Signum
    Simply pull out the heater control panel and slide the bracket in place.
    Pic below shows where it was mounted in my car with me holding a phone holder over it.
    http://www.vectra-c.com/forum/attach...1&d=1182335537
    Link below shows where it came from, where it fits, & how much it cost.
    http://www.noholesbrackets.co.uk/page73.html
    Absolutely mint, selling on as I've gone BlueTooth & have fitted a vent mounted phone holder instead.
    How much are you selling it for dude?
    I knew I forgot something.
    £5 + post (couple of quid should do it).
    Regular Member bigun's Avatar
    Feb 2007
    Newcastle UK
    PM sent
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Juts to add you can also & it fits better if mounted higher up.
    There's a cut out in the metal which locates around a piece of plastic trim slightly higher up the console. You need to pop out the bottom switch blank to fit aswell as the heater control which when refitted actually holds the bracket in place nice & tight.
    Well done Ben, didn't know that.
    bigun, PM replied.
    Bttt
    Feb 2006
    Dorset
    also a bit of double sided stops it marking the dash as they rub , as ben says they go higher up pull out the junk tray pop heater controls out and remove the blank below the hazzard stick the bracket there the balnk holds it in place then .
    Mar 2007
    Hull
    ill take it mate i need one
    PM sent
  1. Centre caps and phone Bracket
    By lizard in forum Parts for sale
    Last Post: 23rd January 2010, 19:39
  2. No Holes Phone Bracket how do I remove it?
    By S16XTY in forum Electrical & ICE (including SatNav)
    Last Post: 8th August 2009, 20:27
  3. Dashmount Bracket - Vectra/Signum Pre-Facelift
    By sonic in forum Parts for sale
    Last Post: 20th March 2008, 08:53
  4. Dashmount Bracket- Vent Mount for Vectra / Signum
    By bennyk in forum Parts for sale
    Last Post: 17th March 2008, 11:16
