Thread: Wheel Arch Gap
    May 2007
    Reading
    Default Wheel Arch Gap
    I have the Design model and was just wondering is the gap between the tyre and the wheel arch too big. Seen a few Design's and my gap looks larger.
    Up Norf
    no just too much rubber! needs 18's
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    looks ok from here m8, just one thing though, if you drop it of the kirb is it still the same ? i guess its just on standard size rims/tyres ?
    Midlands Mod Shop - NFFC.
    Up Norf
    Default wheel arch gap
    this is 18's
    May 2011
    London
    Hi, I have the smae problem with my Veccy SXI - Previous owner changed the front wheel coil springs. Could this be the problem?
    I have a 15cm gap and can honestly say this is not normal as I have seen many similar to mine without the gap. I have 16" rims whith trye size 205/50/16
    Can anyone recommend me the correct spring that I can replace and see if it makes a difference.
    Sorry about the essay - this is my first response - One more thing you guys are fantastic and doing a great job here. I have saved £££ Thank you for you hard work.
    Regular Member Jezzy's Avatar
    S.E
    Shaka, you've also got the wrong tyres on your wheels, they should be 55 profile, so your tyres are too low profile, hence why the gap to the arch will look even bigger.
    Sep 2010
    preface cars look lower and maybe actually are,.. the pf SRI looks lower than the facelift
  1. Wheel arch detailing
    By paul_sri150 in forum Detailing and Car Care Discussion
    Last Post: 11th June 2011, 10:46
  2. Still got clunking from o/s/f wheel arch.
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2011, 20:44
  3. screws in wheel arch
    By bower in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 20:45
  4. Wheel Arch Protectors - for Estate
    By textilewales in forum Styling
    Last Post: 7th March 2010, 08:54
  5. Front wheel arch liner
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2008, 08:50
