Thread: Knocking noise when braking?
    May 2007
    HULL
    confused Knocking noise when braking?
    On the way to work this morning noticed a slight knocking noise coming from my Vec, it was only when braking a very faint knock noise from drivers side, it wasnt contious knock just one slight knock when braking, it wasnt doing it when stationary just when driving, all pads were changed 2 weeks ago, any help would be marvellous cheers!!
    52 LS 1.8 16v - L.S. stands for looks sexy. pics coming soon.
    morton
    could be the pads moving a little when you brake ! or possibly a joint or link arm ! or even worse the bottom arm ! eek ! i'd jack it up and give it a wobble ! see if you can get it to do it !
    sounds like they didn't use pads with the proper size backing plate, so they move in the caliper.. it's too much of a co-incidence..
    I'd lay very good money they fitted pattern pads as they are just that bit too loose in the caliper and the knock is when the rotation of the disc pulls the pads round in the caliper.. not dangerous, but it shouldn't be there and doesn't happen if you fit VX pads.
    May 2007
    HULL
    Default Knocking noise when braking?
    Cheers guys, the pads were done about 4 weeks ago so would it just start knocking now,since the pads have worn down a little? Am I okay to leave them or should I get them changed? I got the pads off ebay! Have I been ripped off £38.00 front and back pads.
    Nicking Ya Dinner.
    Did you put copper grease on them? if you didn't take them back out and apply some.
  1. Knocking sound when braking
    By JezzerD in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2011, 20:44
  2. Knocking from front under braking
    By nick_s in forum Suspension, Wheels & Brakes
    Last Post: 30th March 2011, 20:23
  3. Noise when braking
    By richje100 in forum Suspension, Wheels & Brakes
    Last Post: 28th August 2010, 17:16
  4. Knocking noise when braking!!
    By dave collingwood in forum Vectra C / Signum Troubleshooting
    Last Post: 8th May 2008, 07:53
  5. knocking from rearwhen braking?2007 28k
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2008, 15:39
