Page 1 of 14 12311 ... LastLast
Results 1 to 10 of 135
Thread: Vec 3.2 Gsi
    Regular Member Mick B's Avatar
    North East
    Default Vec 3.2 Gsi
    Need some help lads.
    Went to see a 54 plate Vec Gsi yesterday and was well impressed.It was in my fav colour star silver so life is perfect.
    What I need to know is what specs should I expect xenons etc ,and any issues I should look for.Is the fuel as bad as some say.My 2.5 Vec B was modded and returned 26mpg so anything around that should be ok.
    How does the C compare to the B model.
    Also the head unit has a tape deck so should it have a multi changer in the boot ?
    Is the Cam belt change on this engine around 40,000 as its just hit 42,000
    Cheers for any advice
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    54 plate should have most of the toys
    i get between 23 & 27mpg depends how i drive it
    c is bigger and faster than the b
    i have tape deck and also a 4 cd multi changer in the same unit so u should have it too
    yes the cam belt needs changing at 40,000
    tell him to put a new belt on b4 u buy it otherwise its a £350 bill for u to do it.
    you should expect split climate control, rain sensing wipers, auto dipping interior mirror, 1/2 leather at least..
    the official interval for the cam belt is 80,000..but i dare any one to leave it that long....
    Fuel is a bit like how you drive it.. i drive mine hardish, and get around 22-25 average.. kick it hard and you'll see 4mpg easily...but shove cruise on at 70 on the m-way and you'll easily see over 30mpg..
    Jun 2007
    Sittingbourne, Kent
    i m getting about 26mpg at the moment . Would like to know if anyone gets anymore than this????
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Quote Originally Posted by maf View Post
    Nope 25mpg over 25K mixture of town and motorway driving, more than happy with this given the fun I get driving it
    May 2007
    Walsall
    My 54 GSI is returning 32mpg each tank driven carefully using cruise @75 alot. I comute about 110 miles a day
    My Car has No headlamp washers, or Xenons!!! Its a sept 2004, I think they became an option, can anyone confirm?
    Regular Member muffking's Avatar
    I get on average 26mpg with mixed driving, or 18mpg if it's pure town driving. It's more down to the driving than the engine though as you can easily see over 3mpg like Mark says, but it's hard to drive a car like this slowly when there's so much fun to have, you just end up being a bit throttle happy for the hell of it.
    Toys wise, self leveling xenon's will show that it's probably not ben in an accident as well as headlight washers (although these seem to be questionable at the moment as to which year gets them, my '53 plate did). Check the dual climate works and the electric mirrors as my n/s won't move vertically.
    Check the oil filler neck for mayo as this is an area that Mark highlighted some time ago that suffers from condensation with it being outside the engine. It can be used to blag an oil service, but many of us just removed the filler neck and refitted the cap to eliminate mayo build up in the filler neck & cap.
    Comparing it to the Vec B, I moved from a 2.5 GSi to the 3.2 GSi and found myself asking the same questions almost this time last year. The 3.2 is much more fun, but my personal opinion is that the B had a better build quality other than the old dash creaking, and the old GSi had better handling, but the power, huge spec list and much more modern look of the car & interior more than make up for it, I don't think I could go back to the old Vec B again.
    mines a jan 04 (53)and mine has the standard equipment that has been mentioned , i drive about 8 - 10 miles a day and i get 20 - 24 mpg but i well happy because a tank usually lasts me 3 weeks :-)
    Regular Member j13hdb's Avatar
    Nottingham
    Does a timing belt not need doing every 8 years or 80k as my Vx garage has led me to believe?????? 3.2 Sig Elite
    Apr 2006
    Vehicle : saab 95
    Engine : 2.3t
    Quote Originally Posted by j13hdb View Post
    the book says so
    my dealer advised me to change mine around 40,000 im just sorting the pennys out to get it done.
