Thread: brake warning light
    Jun 2007
    west yorkshire
    Default brake warning light
    Hi
    I just purchased vectra 2.2 dti sxi who hada service back in february where its brake pads were changed by Vauxhall.
    but after 2 weeks of driving it the light has come on.. happened the day there was heavy rain flodding everywhere!
    the pads seem fine alot on them yet so what else could it be? the sensor?
    if so is the sensor easy to change?
    cheers in advance
    TJ
    Jul 2006
    there's a sensor wire that plugs into (i think) the offside pad. it should have been changed with the pads, i'd try that first. about a tenner from the stealers.
    heavy rain and flooding??.... check for moisture in the loom plug under the passengers side front wheelarch, where the sensor lead plugs into the cars loom, it may well have water in to as it's inverted the way to catch it.....also check that the brake end is properly connected as well..
    Jun 2007
    west yorkshire
    hi
    Thanks for the replies. I just went to local garage they said the pads are fine. Thought id clear that. So he moved the sensor wires but that didnt help.
    He advised to get diagnostic done as it could be anything linked to brakes. Is that true?
    Or is it best to try what Gsi 3.2 said above and if no joy then go for sensor
    cheers
    wiggling the wires won't check if the plug is full of water....
    take it apart and check it's dry inside..
    Jun 2007
    west yorkshire
    Hi
    Ok will do that if it dry then is defintely a new sensor?
    i take its quite easy to put in
    cheers
    Administrator plasma's Avatar
    On the Forum
    572 Post(s)
    Engine : 150
    Mileage : 74000
    yes, quite easy indeed..
    morton
    got this problem on mine too ! i'm ignoring it ! he he
    Jun 2007
    west yorkshire
    Smile
    Lol!
    oh yeah might as well ask this question as well
    its about tyre pressure
    what should the tyre pressure on tyre size: 215/55z R16 93W
    cheers
    Jun 2007
    west yorkshire
    just to let you know it was the sensor wire which had a broken connection.
    All sorted now
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. 3rd brake light warning
    By madvenny83 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 07:26
  3. Brake warning light
    By dandsi in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2010, 16:32
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Brake warning light
    By scar_vectra in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2007, 12:48
