Results 1 to 10 of 16
Thread: it didn't work!
    Up Norf
    Smile it didn't work!
    spent ages doing this speed camera mod for my sat nav http://www.bmwnavaddpoi.co.uk/. thought it might work as the CD70 reads BMW discs, but it didn't work!
    If i can mod the CD70 firmware it'll work.....
    Been at it ages i'm determined lol
    Just *ahem* downloaded latest firmware 07/2005 but made no difference.
    I'll keep looking....
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Have you tried it using DVD's as the site says, as the cd70 only takes CD's doesn't it?
    I have the CD70 in my car and when i get back from London, i'll give it a go.
    I have tried doing this sort of thing in the past, with no success, as the firmware is the operating system and the software on the nav cd's forms part of that, loaded at boot.
    I'll put the info i have gained up on this site once i get back. Maybe we could get to the bottom of it, but the BMW fix is the first i have heard of anyone doing this.
    Up Norf
    Nope CD70's don't read DVD's, however some BMW's use a single country CD, these single country CD's use the same layout as the website shows and the CD70 reads these just fine.
    I did the mods as the site suggested to one of these CD's and it worked (in my mates BMW) but the CD70 just read it as a normal map CD worked as normal but no speed cameras.
    Interestingly thought the european DVD90 in the vectras uses the exact same DVD as on that site, as i downloaded on for my research.
    Up Norf
    Not sure if you noticed but you can get the CD70 to show petrol stations etc on top of the map, all i need to do is work out how to change that to cameras!
    Up Norf
    anyone know how to decompress the CarinDB file off the disc? this is the answer!........
    Regular Member Ralph wiggum's Avatar
    Oct 2006
    Bexleyheath, Kent
    Quote Originally Posted by armstma1 View Post
    How is this done mate???? Sounds Good.
    Up Norf
    the cameras or the petrol stations?
    still working on cams but any poi can be shown on top of map from the settings button i think? anyway click show poi and pick the one you want shown.
    once i manage to replace an rubbish poi with the cams i've cracked it!
    but first i need to decompress the file.
    Up Norf
    awwww c'mon boys where are the computer boffins?
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    busy counting our bits...and bytes.
    On another planet
    Engine : 2.0
    I've looked at the db file and it does look like a data base, but a 'dynamic' one. i.e the computer is just reading referances off it and nothing else. They are locked to a specific GPS location, so, as the computer knows what GPS position it is at, then as it polls the db it knows what symbols to display (they are encoded into the flash memory on the head unit) so, if you replace the db locations with speed camera locations instead, then this will do the trick. But i'm not even going to try now that i have had time to look at it.
    Also, the locations of the speed cam, if you could do this would only show as petrol station, airport icons etc, not as speed cam locations, because there is no symbol for speed cams on the firmware. You would also not get any audio warning of the speed cams....Unless you linked it to one of the coded in messages. There are quite a few on there, some that you will never hear (open up the software folder on the software disk and have a look)
    Also the sound is decoded by a dedicated IC. I think you have a good idea, but it is not feasable to do.
    P.S. I'm still trying.
  1. Spanner light while driving to work with no code and usually same point when driving to work?
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2012, 21:52
  2. will this work?????????
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2009, 21:06
  3. To work or not to work that is the question
    By garvey in forum The 'Off Topic' room
    Last Post: 31st December 2008, 19:02
  4. warranty work paper work ???
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2008, 00:21
  5. Anyone else still at work...?
    By izonoky in forum General Chat
    Last Post: 24th December 2007, 13:35
