Results 1 to 10 of 15
Thread: Problem after battery disconnect
    Regular Member Penfold's Avatar
    May 2007
    Sheffield
    Default Problem after battery disconnect
    Can anyone shed any light on this annoying little problem?.After resetting ECU after airbox mod i now have to keep my finger on the power window button to get them all the way up or down where as before i just needed to press for a second or so then they just carried on on their own.Have i caused it or is it just coincidence?
    Hertfordshire
    You just need to reset them, so they know their limits.
    Wind them all the way down, keeping your finger on the button until you hear the motor stop, then do the same going up, and that should sort it.
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Easy fix........put both windows down a bit. Then hold both Up buttons until the windows go up, BUT, keep holding on to the buttons for a few more seconds.
    Done
    May 2007
    Sheffield
    Thanks alot guys i ll go try it
    Up Norf
    i read somewhere that the air box mod was actually making the car slower. something to do with the lack of swirl over the maf sensor throwing the mixture out.......
    May 2007
    Sheffield
    OMG! The 5h1t you guys know just amazes me
    Worked a treat
    THANKS ALOT it was drivin me nuts
    Up Norf
    ps cant believe you went and did that at 11pm LOL coudn't it wait till morning?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by armstma1 View Post
    That will be the trumpet bit mate, leave that on, just mod before the filter.
    May 2007
    Sheffield
    Like i said it was drivin me nuts.....Probably O.C.D or sumfin
    Regular Member LJ sxi-nav's Avatar
    Winchester
    I've only done the airbox mod and I've not noticed any LOSS of power; but equally have not noticed an INCREASE either. What I have noticed is a much smoother power band as I increase engine revs. However I have not performed the ECU reset, as I need to sort out getting a K&N filter. Will reset ECU after filter is fitted.
  1. CD30 battery disconnect
    By 19CDTi in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2012, 20:48
  2. Battery problem
    By robhullfury in forum Diesel Engine related
    Last Post: 23rd March 2012, 02:53
  3. Disconnect battery?
    By yoclick in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2009, 09:46
  4. Will I need to disconnect my battery
    By ballmonkey in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2007, 14:37
  5. disconnect battery after remap?
    By trucker in forum Tuning
    Last Post: 17th September 2006, 08:49
vectra ecu problem after disconnecting battery
what do I do after disconnecting a battery of a Vauxhall vectra
