Thread: tech 2 towbar
    Regular Member amos's Avatar
    s,wales
    Default tech 2 towbar
    i got my tow bar to fit, its got oem relay kit will it need to go on tech2 too work my last one whent on.
    thanks
    Hertfordshire
    Some do, some dont, no one knows till you plug em in and try em.
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    my 52 plate elite needed tech 2 to enable the electrics ,having said that my mates 53plate elegance was ok , he just hard wired the electrics and it was ok!!"!
    mine didn't need it...it's just a lottery..
    oh, and i used the VX kit if that helps at all?..
    Regular Member G.O'Rilla's Avatar
    Jul 2006
    On the road
    Mine was done by a Witter approved company and it went straight on - he had some sort of relay system that they supplied to avoid having it Tech 2'd. It didn't work at first (simply dead) for the reason that the system was expecting 7 wires in the plug connected to the lighting board and there were only six. Could not understand it as it worked perfectly on the Ren-no and my wife's Nissan. Eventually took the plug apart and realised what the problem was.
    s,wales
    Ok thanks ill try and see.
    Warwick
    I had the Vx OE kit and it needed Tech2 to enable the dashboard towing lamp direction indicator tell-tale to work plus cutting out the rear fog lamps and reversing lights when a trailer or caravan is attached.
    Dealer charged £12 for this.
  1. Tech 2 programming Towbar
    By Chuff in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2012, 07:18
  2. towbar help
    By montyfert in forum Bodywork & Interior
    Last Post: 3rd September 2012, 10:48
  3. Which Towbar????
    By Nezza42 in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2012, 07:57
  4. tech 2 req for towbar electrics
    By movianto in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2012, 17:00
  5. tech 2 towbar
    By wirrallad in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2010, 22:37
