Results 1 to 10 of 13
Thread: problems with 1995 2.0 SRI at idle...
    Regular Member Cerealuk's Avatar
    May 2007
    Dorset
    Default problems with 1995 2.0 SRI at idle...
    I know it's not a vectra C but hopefully someone has an answer as its bugging me like hell.
    My current car (95 vectra 2.0 SRI) has got a very annoying problem. Basically the car revs too low at idle (sometimes stalls or shudders) and when i pull to a stop at junctions it often cuts out. I can solve the problem by tightening it up a little however a few weeks down the line I have the same problem again and have to tighten it again. It has got to the point where im running out of screw thread The airflow jobby which the ECU (i think it is the ecu anyway) plugs into has been changed with no improvement. Im about to sell the car as Im getting a vectra C, and I know I can temporarily fix it with a couple more twists however I'd prefer a more perminent solution for the next owner.
    Also the onboard computer display doesnt function now and simply says "program" is there a way to reset this or is it ******ed ?
    Any help would be appricated
    Thanks muchly
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    sound like you ICV -idle control valve have you tried cleaning it?
    May 2007
    Dorset
    Nope not tried that, where would I find it and how best to clean it ?
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    are you running an induction kit by any chance? as these engines dont like them and trhey can cause the problems you have mentioned, im not sure where exactly the air idle valve thingy is situated but a workshop manual will help also maybe try some carb or fuel injection cleaner in the intake as it might be coked up and causing problem too
    May 2007
    Dorset
    the engine is stock, might try and pick up a hayes manual and work out where the bits that need cleaning are
    S.Wales, Nr Swansea
    you will have to remove the rubber pipe that connects to the throttle body, once its off you will see to the left of the throttle body a type of long cylinder with a wire connector going to it, thats the ICV, the pic below circled shows roughly where it is under the rubber pipe
    May 2007
    Dorset
    Aha thanks,
    Shall have a peak in the morning when I can see what Im doing Will let you know the results
    Regular Member LJ sxi-nav's Avatar
    Winchester
    my 99 Veccy B had a similar problem, it was a 1.8 (X18XE1) engine. It actually had a fault logged on the ECU as well (eng. mgmt light was on). Had the code read, but can only remember the mechanic saying you could try a new throttle body housing for lots of dosh, might or might not cure it; or just live with it (and the eng. mgmt light).
    After finding something on another online forum, I cleaned the throttle body housing; a few bolts (four?) under the plastic engine cover; along with a few pipes and connections and the unit comes away - easy job. Cleaned the whole unit up, including unblocking all the holes where breather hoses etc connect and it did seem to make a difference. Didn't cure the eng. mgmt light though!!! oh and a new gasket is needed, think I made one with gasket paper.
    Oh and the eng. mgmt light was cured later - The bulb in the dash blew!!!!
    S.Wales, Nr Swansea
    lol, no probs mate keep us updated, if the cleaning of the ICV and Throttle body dont cure it im sure we'll think of something else
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    if you need a idle control valve then i have some that i can sell for the
    they are for the 1.8 16v / 2.0 16v so pm me if you want a price
    i have -
    2 x used ones which work perfectly and like new (as piccy )
    1 x brand new in the box
    piccy of the iac`s
  1. 2003 1.8 idle and emission problems
    By omegapete in forum Engine & Drivetrain
    Last Post: 7th November 2012, 21:50
  2. 2.2 dti idle problems
    By ssnape in forum Engine & Drivetrain
    Last Post: 3rd September 2012, 14:11
  3. 2.2dti major idle problems
    By dieseld4 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th March 2011, 14:35
  4. idle problems
    By mtek6814 in forum Engine & Drivetrain
    Last Post: 19th May 2008, 13:14
  5. Vecta 1.8 ecotech stalling / idle problems
    By baznap in forum Vectra C / Signum Troubleshooting
    Last Post: 5th February 2008, 08:35
