Thread: Central locking problem
    Mar 2007
    GB
    Default Central locking problem
    Twice now I've been unable to unlock the door with the keyfob. Had to use the key in the door to get in. Works ok after leaving it for a while. Am i doing something to upset the car perhaps anyone have any ideas what it might be
    Admin plasma's Avatar
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    have you tried the spare key to see if that one works ok, if it does means the battery on the remote on its way out? Also if it keeps being pressed accidently whilst in your pocket say. it will lock the key out for a while.
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    If it works then doesn't I'd agree with the battery route. The key battery should be changed every year and don't forget to change the battery in the spare too.
    Nicking Ya Dinner.
    Plasma's got it in one, I used to get this and it was normally after a long press on the fob.
    Melbourne, Australia
    Try re-synchronising the key with the car. To do this:
    1. turn the key to the run position
    2. within 30 seconds press one of the remote buttons
    The doors should lock and unlock to indicate that the key transmitter has been re-synchronised with the receiver.
    Or to use some else's words:
    Mar 2007
    GB
    Thanks everyone, I'll give these things a try.
    Must admit, panicked for a bit when no doors would open, took a while to notice that the door handle has a key slot
  1. Central Locking Problem
    By hairymark in forum Troubleshooting
    Last Post: 30th January 2013, 14:41
  2. Central locking problem
    By Badger59 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2012, 21:47
  3. 1.8i 16V T Reg Central Locking problem
    By Mytac in forum Electrical & ICE (including SatNav)
    Last Post: 31st December 2008, 10:12
  4. Central Locking problem
    By NKB in forum Troubleshooting
    Last Post: 28th December 2007, 02:24
  5. Central Locking Problem
    By Penfold in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2007, 22:20
