Thread: keyfob battery
    Regular Member TonyR999's Avatar
    Cumbria
    Default keyfob battery
    Hi Chaps,
    simple question, my remote has stopped working on the spare key, what battery do i need to replace in my key?..is it
    CR2032
    my car is a 2003 SXi
    i am away from home at the moment so unable to look it up in the handbook documentation
    cheers
    yep, thats what you need, just remember to swap the old battery for the new one in under 30 seconds or the key will need programming at VX again..so get the packet open before fiddling with the key and work quickly and try not to break the little white plastic tags on the battery mount
    Cumbria
    Cheers GSi 3.2, will get right on it when i get back home
    Regular Member j13hdb's Avatar
    Nottingham
    I think- when you have changed the battery you then have to put it in the ignition,switch it on and press the open button twice to make it work.
    Someone far more technical than me should confirm this just remember needing to do something when I changed my battery!!
    thats for veccy b's......
    if you stay under 30 seconds when changing the battery you'll be fine..
    Melbourne, Australia
    It also works for Veccy C's See this post for re-synchronisation procedure if you take longer than 3oish seconds to change the battery.
  1. Newbie & Keyfob plus
    By bigmac12 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 20:50
  2. Keyfob advice please
    By Partyvan in forum Electrical & ICE (including SatNav)
    Last Post: 5th April 2011, 19:09
  3. Keyfob Mod
    By Aidi in forum Styling
    Last Post: 8th October 2010, 10:20
  4. keyfob / key
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2010, 21:56
  5. HELP with keyfob!
    By byebyeitsagsi in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2009, 22:36
