Results 1 to 3 of 3
Thread: Oh god NO POWER!!!!! HELP
    Chester
    confused Oh god NO POWER!!!!! HELP
    On my wy back from the south last night i joined the M5 only to find when i put myfoot down all there was hardly any acceleration, as if the turbo had died. looked at the dash and low and behold the car with the spanner through it appeared!!! called the RAC who said about the "limp home mode". Ive tried restarting the car and the fault is still there. I did notice on the journey back more blue smoke than usual from the car which by the way is a 2.0 DTI. Can anyone help?? is this going to be another expensive job??
    Regular Member robzc's Avatar
    Mar 2007
    South West
    Could be a number of things Mate, limp mode is simply a get home mode when the computer picks up something wrong on the motor, could be just a faulty sensor or something. A lot of us on here have had this happen, but unfortunately you'll have to go to the dealers to be told what's causing it. Mine was intermittent and reset after restarting the motor and then suddenly the fault completely dissappeared a few days ago.
    Try disconnecting the battery for 15 mins & then restarting, may reset the fault, but if it's a faulty sensor, it won't go away. Good luck!
    Chester
    Default Its the EGR valve
    Nice one thanksjust come back from the dealer and its an EGR Valve that needs replacing £350 for P+L!!! hummmm........ never mind
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 7th January 2010, 17:50
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
