Results 1 to 10 of 22
Thread: 150 caterman doesn't fit ??
    Jun 2007
    hull
    Default 150 caterman doesn't fit ??
    good morning all,
    my first post and problems already...!!
    read through the fantastic source of info and decided to get a caterman
    whipped the engine cover off and on the end of the common rail - right on top of the engine - unplugged the 3-pin plug.
    the caterman will no way fit, it has three lugs on it where the original has two. the lugs are all offset and so it won't go on at all...???
    am i looking at the right plug?
    am i looking at the right caterman?
    help would be much appreciated.
    while the bonnet was up I did the K&N and trumpet mod - two fag butts and a milky-way wrapper in there !!
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    Can you take some close of photos of it? I had a "Caterman" before, I was one of the unlucky few who's car it would not work with at all, even sent photos of it installed to T-Tuning to confirm I put it on right. Mine had to go back for a refund.
    So yeah, photos on here (or sent to T-Tuning) will help sort your problem out - it may be that you need to cut a couple of the plastic lugs on the TB with a sharp knife, because the connections on it are not the greatest.
    Feb 2007
    North west
    I had to cut the lugs with a stanley, i fitted mine last Friday and at first it just wouldnt squeeze in. Compare it to the original fitting then trim whatever lugs dont line up, it stays in cause of the rubber seal anyway.
    Regular Member archerz's Avatar
    May 2007
    Teesside
    Engine : 3.0 v6 CDTI
    Mileage : 57500
    i used a sharp knife and trimmed off the lugs to fit. after that no probs!
    Jun 2007
    hull
    thanks for the help - its been torential rains since i came back in.
    as soon as it stops i'll pop out for some photo's
    cheers
    Here, there and every where!
    Never mind the photo's just get those lugs cut off and get it fitted
    Jun 2007
    hull
    just concerned if it still doesn't fit i can't send it back...
    May 2007
    Teesside
    Mileage : 57500
    basically the 2/3 lug bits that stick out need trimming off. and take off the end yellow bit from the Vauxhall connector (on my model anyway).
    Jun 2007
    hull
    ok ok i'm off outside with a sharp implement
    what was the result???..or are you driving the wheels off it now??..
  1. Caterman Box
    By PeteRs in forum Parts for sale
    Last Post: 14th May 2008, 14:08
  2. caterman box
    By alijlacy in forum Diesel Engine related
    Last Post: 20th April 2008, 16:41
  3. caterman Box
    By carport in forum Parts for sale
    Last Post: 24th February 2008, 16:06
  4. Was it the Caterman??
    By stoneyVectra in forum Diesel Engine related
    Last Post: 8th November 2007, 11:23
  5. Caterman Special/Caterman box...
    By MyLittleEgg in forum Diesel Engine related
    Last Post: 24th September 2007, 18:22
