Thread: removal of stereo
    Question removal of stereo
    my bruv is trying to replace his standard stereo with an after market sony,whoever he can't get the old one out.
    he has removed the allen keys and removed the switches around and also removed the heating panel below..He can't seem to be able to remove stereo from cage, any ideas please.Had mine replaced in shop ,so i have no idea..
    many thanks...
    Regular Member philzi's Avatar
    East Yorkshire
    My understanding is you remove the allen bolts and then use the Double DIN keys (or a pair of normal ones bent to fit or maybe an old coat hanger) and the radio will be able to be removed without the lengths your brother has gone to!
    Need to go to halfrauds and get the "double din stereo removal tool"..... its like a piece of coathanger wire bent into a U and releases the 4 catches in each of the holes simultaneousley. when inserted into the holes on either side push the tools away from the centre and and pull.
    If i've confused you let me know.
    sorted many thanks
    you can ( and i have done ) bend a single din removal tool to fit the double ( well 1.5 din cuz thats what it is ) stereo facia
    a small tip, get a small bit of insulation tape or masking tape around the holes, it will stop you from scratching the unit with the removal tool,
    BB
  1. Stereo removal help?
    By MarkiQon in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2009, 17:07
  2. Stereo Removal
    By VectraMat in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2008, 16:42
  3. stereo removal HELP!!
    By whatthevecisup in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2008, 16:28
  4. help on stereo removal
    By kns in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2007, 16:57
vectra stereo removal www.vectra-c.com
