Results 1 to 10 of 21
Thread: Rear Fog lights
    Regular Member Bucko's Avatar
    Pudsey
    Default Rear Fog lights
    Newbie type question but......
    Why is the passenger side rear fog light not wired up?? There is a bulb in there. My brother who has a 3.0 CDTi was telling me that his had never worked and I thought that something was up with it, but when I swapped the back light cluster for the Lexus style lights I noticed that there is nowire going into the connector.
    That's on a september 03 GSi.
    Anyone any ideas??
    Full Member Big Sig's Avatar
    It doesn't need to work thats why. Only the offside one is required. You can link it up from the working one if you wish. The veccy has a nice little system that if one bulb fails it will intensify another bulb to compensate
    Feb 2006
    Guttedsville
    Basically, it is safer to have one side of the car illuminated during foggy conditions, so that following drivers can identify the brake lights easier.
    Why Vx leave the bulb there is anyone's guess. Makes a handy spare though I suppose!
    Pudsey
    Yep your right in that it is handy as a spare. just think it's silly to go to all that trouble and then not wire it up
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    It's a european thing. that new cars only have one fog light on the offside. First mod I made I linked mine up so I have two rear fogs, simple job, took about 30mins I think . Read this link for a full explanation
    http://www.vectra-c.com/forum/showthread.php?t=975
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    My manual actually say that only one side works and the other side is a spare bulb.
    I wired mine up too though, brake lights should be easy to spot since there is another bank of red LEDs in the middle of the car.
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    when i had my towbar electrics done in one of the menus on the tech 2 it gives you the option to enable it , but i agree with Andy its safer to have one side illuminated
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Quote Originally Posted by willc01 View Post
    Quote Originally Posted by nutron View Post
    How did you do it guys?
    Quote Originally Posted by SteveH View Post
    There may be a Tech2 option but i don't think it is for the rear N/S fog as there is no feed cable to the unit so pointless menu option perhaps it's there for cars that don't have fogs
    Quote Originally Posted by Neil View Post
    Run a feed from one light across to the other one. The nearside fog has no cables running to it
    thats probably cause european cars have the other one working. Maybe the same software
  1. Led Side Lights Fitted & 2 Rear Fog Lights
    By wardy23 in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2012, 23:16
  2. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
