Thread: Oil Warning Light
    Regular Member deez_nutts's Avatar
    Jun 2007
    Wiltshire
    Default Oil Warning Light
    Hi all
    I've got an '02 2.0 DTi - wierd thing is happening.
    When the engine is hot and idling the oil level warning light comes on but goes off when i rave the engine or driving. I've checked and topped up the oil. No sign on leaking or loss of performance.
    Any ideas?
    Regular Member daneboy35's Avatar
    darvel,ayrshire
    Is it the correct grade of oil your using
    either that or it sounds like the engine is internally worn as revving the engine increases the flow of oil in a worn engine and will put the light out..this requires more serious, professional investigation
    Jun 2007
    Wiltshire
    the car was last serviced by the vx dealer in january so im assuming they used the correct oil.
    With regards to a worn engine wont that cause excessive smoke, loss ofpower and excessive oil consumption? Veccy is sufferring from none of these.
    Does anyone know what happens if you dont replace the oil filter when servicing?
    it will just restrict the flow to the point where the filter bypass valve will open.. nothing else dramatic will happen
    When i say 'worn' i don't mean anything to do with the pistons or rings which is the type of wear you are describing..The waer i am talking about is the crankshaft main bearings and Con rod bearings.. these have a very large affect on the oil pressure within an engine, and if worn can drop the oil pressure quite dramatically..for my money, it's either a worn oil pump, or a stuck pressure releif valve inside the oil pump... or more worryingly the bottom bearings worn out.
    Jun 2007
    Wiltshire
    the car is going to an independent garage in the morning - i'll see what the have to say. I have notice the oil filter is covered with oil - could i have a filter with a damaged seal?
    you could have a damaged seal, but that would go hand in hand with massive oil loss as the oil moves round at quite a rate, if the seal had failed then i'd expect the sump to be empty
    Jun 2007
    Wiltshire
    Finally after 4 days i get a phone call from the dealers. It turns out the oil switch is leaking and needs replacing. Im hoping to get her back tonight.
  1. Warning Light
    By chrissy white85 in forum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
