Thread: Installing a Toad alarm!
    Regular Member um20's Avatar
    Mar 2007
    Doncaster
    Default Installing a Toad alarm!
    Bit of a long shot this, but has anyone ever fitted a TOAD A850 overlay alarm to a car? I'm trying to fit this to my Corsa and they don't provide installation instructions if you're not an approved installer.
    I'm not fussed about the warranty and I'm not declaring it to the insurer as being fitted, I just want to put the thing in for my own peace of mind. Only problem is there are about 1,000 wires coming out the thing! Once I know what each wire is I know where to connect them on the corsa!!
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    is there anytink on the net i did this will a clifford concept to a corsa B and the best way i found was via a clifford website/ forum
    good luck
    baz
    Up Norf
    all thatcham approved alarms have single colour cables, they are identified on the very end of the cable, so that once installed it's harder for a heif to identify the cables as you normally cut the end to length.
    Check there isn't anything printed on the very end of the cable......
    Mar 2007
    Doncaster
    Thanks for the well-wishes Baz, I think I might need them!
    I've been on another forum for installing car alarms and I think I've got it sussed. The problem is there are 25 wires I need to connect (or not connect!) and I just want to be sure.
    It's a bit easier than fitting other alarms as the A850 is an update alarm for cars with central locking/immobiliser fitted as standard (i.e. I can use my existing remote as it is armed/disarmed directly from the central locking).
    The worst bit (perhaps) is the cobra window closure module I got from ebay - that is just a black box with 7 pins numbered 1-7. If anyone knows anything about that I would be well chuffed!!
    Mar 2007
    Doncaster
    Quote Originally Posted by armstma1 View Post
    Thanks for the tip armstma, only thing is my cables are every colour under the sun! It's like a ****** rainbow!!
    member of the smoke patrol 230bhp+
    i think i may have a bit of help for you
    Make VAUXHALL Model ASTRA Year 1997 S.O.E CAT. 1 MAR 98 (CDX SRi) CAT. 2 MAR 98 Ref. V1
    Siren Location TOP OF BULKHEAD
    Alarm Location
    Harness Entry DRILL HOLE IN N/S BULKHEAD NEXT TO MAIN HARNESS MULTIPLUG AND FIT GROMMET
    Chassis Ground BROWN – MAIN EARTH POINTS BEHIND FRONT KICKTRIMS
    Permanent Supply HEAVY RED (PIN 72) WIRE LOCATED IN MAIN HARNESS TO N/S BULKHEAD GREEN MULTIPLUG
    Ignition Supply BLACK/VIOLET (PIN 74) WIRE LOCATED IN MAIN HARNESS TO N/S BULKHEAD GREEN MULTIPLUG
    Starter Immobilisation N/A CAT 2 STANDARD
    Ignition Immobilisation N/A CAT 2 STANDARD
    Fuel Pump Immobilisation N/A CAT 2 STANDARD
    Indicators BLACK/GREEN (PIN 19) AND BLACK/WHITE (PIN 65) WIRES LOCATED IN MAIN HARNESS TO N/S BULKHEAD GREEN MULTIPLUG
    Door Switches GREY WIRE LOCATED IN SMALL LOOM BEHIND N/S KICKTRIM GOING TO N/S/F DOOR SWITCH
    Boot/Tailgate Switch BROWN/WHITE WIRE LOCATED AT LAMP
    Bonnet Switch FIT 639L
    Central Locking Type MULTIPOINT - NEGATIVE Diagram Number “A”
    Lock RED/BLUE WIRE LOCATED IN O/S DOOR HARNESS.
    Unlock RED/WHITE WIRE LOCATED IN O/S DOOR HARNESS
    Window Closing Type TOTAL CLOSING Diagram Number
    SPECIAL NOTES: TO INCORPORATE THE DEADLOCKS, FOLLOW DIAGRAM BELOW USING 4/5 PIN RELAY AND SET THE ALARM TO GIVE A 25 SECOND TOTAL CLOSURE PULSE. IF YOU DO NOT REQUIRE TOTAL CLOSING OR 288/290I2 SET ALARM FOR 3 SECOND PULSE! 970/1 UPGRADE POSSIBLE. NO VOLT SENSE.
    Make VAUXHALL Model CAVALIER Year 1989 S.O.E CAT. 2 94 Ref. V2
    Siren Location
    Alarm Location N/S SUSPENSION TURRET OR BULKHEAD
    Harness Entry USE EXISTING GROMMETS IN O/S OR N/S BULKHEAD
    Chassis Ground USE EXISTING BODY GROUND POINTS
    Permanent Supply HEAVY RED WIRE AT REAR OF FUSEBOX
    Ignition Supply HEAVY BLACK WIRE AT REAR OF FUSEBOX
    Starter Immobilisation HEAVY RED/BLACK WIRE ON ROUND MULTIPLUG ADJACENT TO BATTERY
    Ignition Immobilisation BLACK (IGNITION LIVE) WIRE ON ROUND MULTIPLUG ADJACENT TO BATTERY
    Fuel Pump Immobilisation HEAVY BLUE/RED WIRE ON REAR OF FUSEBOX
    Indicators TO BLACK/WHITE AND BLACK/GREEN LOCATED IN LIGHTING HARNESS BELOW N/S SUSPENSION TURRET
    Door Switches GREY WIRE REAR OF O/S KICKPANEL COMING DOWN FROM SWITCH IN O/S PILLAR
    Boot/Tailgate Switch CONNECT TO BOOT/HATCH LIGHT POSITION ON NEGATIVE SWITCHED SIDE
    Bonnet Switch FIT SWITCH 639L
    Central Locking Type MULTIPOINT – NEGATIVE Diagram Number “A”
    Lock BROWN/RED ON CDL RELAY REAR OF O/S KICKPANEL
    Unlock BROWN/WHITE ON CDL RELAY REAR OF O/S KICKPANEL
    Window Closing Type TOTAL CLOSURE APPLICABLE. Diagram Number
    TOTAL CLOSURE
    NOTE: DIODES REQUIRED FOR TOTAL CLOSURE ON OLDER VEHICLES.
    FIT 2 X 1AMP DIODES BAND SIDE TO LOCK WIRE OF ALARM. CONNECT OTHER SIDE OF ONE DIODE TO THE BROWN/RED WIRE ON VEHICLE. CONNECT OTHER SIDE OF THE SECOND DIODE TO THE BROWN/BLACK WIRE IN O/S OR N/S DOOR HARNESS.
    TOTAL CLOSURE WIRE MAY ALSO LOCK DOORS ON LATER MODELS 94/95 SPEC. TEST!
    SPECIAL NOTES:
    NO VOLT SENSE.
    DEADLOCKING ON THIS VEHICLE IS MECHANICAL ON O/S/F DOOR. IT CANNOT BE INTERFACED TO THE ALARM SYSTEM.
    Make VAUXHALL Model CORSA/TIGRA Year 1994 S.O.E CAT. 2 FROM 94/95 Ref. V3
    Siren Location N/S BULKHEAD REAR OF BATTERY OR N/S SUSPENSION TURRET
    Alarm Location
    Harness Entry N/S BULKHEAD MAIN HARNESS GROMMET
    Chassis Ground HEAVY BROWN WIRE OR EXISTING BODY GROUND POINTS
    Permanent Supply HEAVY RED WIRE ON IGNITION SWITCH LOOM TO COLUMN
    Ignition Supply HEAVY BLACK WIRE ON IGNITION SWITCH LOOM TO COLUMN BLUE MULTIPLUG
    Starter Immobilisation HEAVY BLACK/RED WIRE ON IGNITION SWITCH LOOM TO COLUMN
    Ignition Immobilisation BLACK WIRE IN LOOM TO COIL
    Fuel Pump Immobilisation BLUE/RED WIRE IN MAIN LOOM REAR OF GLOVEBOX OR REAR OF FUSEBOX
    Indicators BLACK/GREEN AND BLACK/WHITE WIRES IN LOOM TO COLUMN STALK SWITCH
    Door Switches GREY WIRE REAR OF O/S/F “A” PILLAR SWITCH
    Boot/Tailgate Switch CONNECT AT NEGATIVE SIDE OF BOOT/HATCH LIGHT SWITCH
    Lock BROWN/RED WIRE IN LOOM TO O/S/F DOOR
    Unlock BROWN/WHITE WIRE IN LOOM TO O/S/F DOOR
    Window Closing Type 824B – FOLLOW MODEL SPECIFIC INSTRUCTIONS IN 824B PACK Diagram Number 4A
    O/S/F N/S/F
    O/S/R N/S/R
    SPECIAL NOTES:
    NO VOLT SENSE. CAT. 1 STANDARD ON AUG 00 CORSA.
    Make VAUXHALL Model MONTEREY Year 1997 S.O.E CAT. 2 Ref. V4
    Alarm Location
    Harness Entry N/S MAIN HARNESS GROMMET
    Chassis Ground MAIN EARTH POINT BEHIND O/S KICKTRIM
    Permanent Supply HEAVY WHITE/BLACK WIRE LOCATED IN MAIN IGNITION SWITCH HARNESS
    Ignition Supply HEAVY BLACK/YELLOW WIRE LOCATED IN MAIN IGNITION SWITCH HARNESS
    Starter Immobilisation HEAVY WHITE/GREEN OR WHITE/BLUE WIRE LOCATED IN MAIN IGNITION SWITCH HARNESS
    Ignition Immobilisation DIESEL – BLACK/ORANGE WIRE LOCATED IN REAR OF FUSEBOX BEHIND FUSE C9 15AMP
    Fuel Pump Immobilisation BLACK/RED WIRE LOCATED IN O/S SILL HARNESS
    Indicators GREEN/BLACK AND PINK/BLACK WIRES LOCATED IN FROM STEERING COLUMN
    Door Switches GREY/BLUE WIRE LOCATED TO THE RIGHT OF STEERING CLOUMN IN O.E. ALARM MULTIPLUG
    Boot/Tailgate Switch CONNECTED O DOOR CIRCUIT
    Bonnet Switch BROWN/WHITE WIRE LOCATED TO THE RIGHT OF STEERING COLUMN IN O.E. ALARM MULTIPLUG
    Lock LIGHT GREEN/RED WIRE LOCATED IN O/S 9 WAY MULTIPLUG FROM DOOR HARNESS
    Unlock LIGHT GREEN/BLUE OR LIGHT GREEN/YELLOW WIRE LOCATED IN O/S 9 WAY MULTIPLUG FROM DOOR HARNESS. SEE NOTES!
    Window Closing Type 824 POSITIVE UP Diagram Number 5A
    O/S/F BLUE/WHITE AT SWITCH POSITION IN O/S FRONT DOOR N/S/F RED/YELLOW IN LOOM FROM DOOR O/S KCIKPANEL
    O/S/R RED/BLUE IN LOOM FROM DOOR O/S KICKPANEL N/S/R RED/BLACK IN LOOM FROM DOOR O/S KICKPANEL
    SPECIAL NOTES:
    NO VOLT SENSE. REMOTE IMMOBILISER FIITED AS STANDARD CAT 2. O.E. ALARM FITTED AS STANDARD OPERATED VIA CDL – O.E. ALARM WILL TURN ON THROUGH CDL. TO TURN OFF O.E. ALARM – CONNECT 2 x 1AMP DIODE BAND SIDE TO ALARM UNLOCK WIRE. CONNECT OTHER SIDE OF ONE DIODE TO UNLOCK WIRE OF VEHICLE AND CONNECT OTHER SIDE OF SECOND DIODE TO ORANGE/BLACK WIRE LOCATED IN 20 WAY MULTIPLUG FROM O/S DOOR HARNESS.
    ROOF – USE 824 MODIFIED FOR 6 SECONDS – TEST!
    Make VAUXHALL Model OMEGA Year 1994 S.O.E CAT. 2 DEC 94 Ref. V5
    Siren Location N/S OR O/S SUSPENSION STRUT OR N/S BULKHEAD
    Alarm Location
    Harness Entry MAIN HARNESS GROMMET
    Permanent Supply HEAVY RED – IGNITION SWITCH HARNESS
    Ignition Supply HEAVY BLACK – IGNITION SWITCH HARNESS
    Starter Immobilisation HEAVY BLACK/RED – IGNITION SWITCH HARNESS – TEST! 2 x BLACK/RED
    Ignition Immobilisation FEED TO COIL/COILS – TEST!
    Fuel Pump Immobilisation RED/BLUE – AT FUEL PUMP LOCATE AT SIDE OF FUSEBOX
    Indicators BLACK/GREEN + BLACK/WHITE – LOCATE IN LOOM TO STALK
    Door Switches GREY PIN 1 CDL RELAY BEHIND O/S/F FOOTWELL TRIM*
    Boot/Tailgate Switch BROWN/WHITE PIN 5 CDL RELAY A/A*
    Bonnet Switch FIT 639L SWITCH
    Lock BROWN/RED – CDL RELAY O/S/F FOOTWELL
    Unlock BROWN/WHITE – CDL RELAY O/S/F FOOTWELL
    Window Closing Type TOTAL CLOSURE APPLICABLE Diagram Number
    TOTAL CLOSURE
    FIT 2 X 1AMP DIODES BAND SIDE TO LOCK WIRE OF ALARM. CONNECT OTHER SIDE OF ONE DIODE TO THE BROWN/RED (LOCK) WIRE ON VEHICLE. CONNECT OTHER SIDE OF THE SECOND DIODE TO THE two X BROWN/BLACK (TOTAL CLOSE) WIRE PIN 20 IN CDL RELAY. IF DEADLOCKING REQUIRED FIT 3rd DIODE BAND SIDE TO ALARM LOCK WIRE UNBANDED SIDE TO RED/YELLOW WIRE PIN 23 ON CDL RELAY
    SPECIAL NOTES: NO VOLT SENSE.
    FACTORY FITTED ALARM + IMMOBILISER ON MOST VEHICLES CAT. 1 JAN 94 ON CD/CDX/ELITE MODELS.
    Make VAUXHALL Model SINTRA Year 1997 S.O.E TBA Ref. V6
    Siren Location O/S SUSPENSION TURRET
    Alarm Location
    Harness Entry ENGINE HARNESS GROMMET
    Chassis Ground O.E. GROUND
    Permanent Supply RED WIRE LOCATED IN FUSEBOX
    Ignition Supply PINK WIRE LOCATED IN FUSEBOX
    Indicators BLUE AND DARK BLUE WIRES LOCATED IN CONNECTOR A ON O/S UNDERDASH
    Door Switches YELLOW WIRE LOCATED IN 16 WAY MULTIPLUG IN O/S KICKPANEL
    Boot/Tailgate Switch AT BOOT SWITCH
    Central Locking Type MULTIPOINT - POSITIVE Diagram Number “B”
    Lock RED/BLACK WIRE LOCATED IN 16 WAY MULTIPLUG POSITION “R” ON O/S KICKPANEL
    Unlock BLACK WIRE LOCATED IN 16 WAY MULTIPLUG POSITION “P” IN O/S KICKPANEL
    O/S/F GREEN/WIRE IN 16 – WAY CONNECTOR IN O/S DOOR HARNESS N/S/F BLACK WIRE IN 16 – WAY CONNECTOR IN O/S DOOR HARNESS
    O/S/R N/S/R
    SPECIAL NOTES:
    NO VOLT SENSE.
    Make VAUXHALL Model VECTRA Year 1995 S.O.E CAT. 2 Ref. V7
    Alarm Location
    Chassis Ground BROWN – MAIN EARTH POINT BEHIND N/S OR O/S KICKTRIMS
    Permanent Supply HEAVY RED – IN TO BASE OF 40 AMP FUSE UNDER SIDE OF FUSEBOX
    Ignition Supply BLACK – UNFUSED SIDE OF FUSE 14 UNDER SIDE OF FUSEBOX
    Starter Immobilisation BLACK/RED – REAR OF BATTERY IN MAIN HARNESS TO STARTER MOTOR
    Ignition Immobilisation BLACK – IN HARNESS TO IGNITION MODULE/COIL
    Fuel Pump Immobilisation HEAVY RED/BLUE – LOCATE IN N/S/F SILL HARNESS
    Indicators BLACK/GREEN + BLACK/WHITE – LOCATED ON REAR OF FUSEBOX
    Door Switches GREY – REAR OF O/S/F DOOR SWITCH OR GREY/WHITE AT O.E. ALARM MODULE BEHIND O/S/F KICKTRIM
    Boot/Tailgate Switch BROWN/WHITE N/S/F SILL HARNESS – TEST! OR BROWN/WHITE – AT O.E. ALARM MODULE
    Bonnet Switch BROWN/GREEN – AT O.E. ALARM MODULE OR FIT 639L SWITCH
    Lock RED/BLUE – DRIVERS DOOR HARNESS
    Unlock RED/WHITE – DRIVERS DOOR HARNESS
    SPECIAL NOTES: NO VOLT SENSE. TO INCORPORATE THE DEADLOCKS, FOLLOW DIAGRAM BELOW USING 4/5 PIN RELAY AND SET THE ALARM TO GIVE A 25 SECOND TOTAL CLOSURE PULSE. IF YOU DO NOT REQUIRE TOTAL CLOSING OR 288/290I2 SET ALARM FOR 3 SECOND PULSE! 970/1 UPGRADE POSSIBLE.
    Make VAUXHALL Model ZAFIRA Year 1999 S.O.E CAT. 1 MAR 9 (ELEGANCE) CAT.2 MAY 99 Ref. V8
    Alarm Location
    Permanent Supply HEAVY RED WIRE LOCATED IN MAIN HARNESS TO N/S BULKHEAD GREEN MULTIPLUG
    Ignition Supply BLACK/VIOLET OR BLACK WIRE LOCATED IN MAIN HARNESS TO N/S BULKHEAD GREEN MULTIPLUG
    Indicators BLACK/GREEN AND BLACK/WHITE WIRES LOCATED IN MAIN HARNESS TO N/S BULKHEAD GREEN MULTIPLUG
    SPECIAL NOTES: NO VOLT SENSE.TO INCORPORATE THE DEADLOCKS, FOLLOW DIAGRAM BELOW USING 4/5 PIN RELAY AND SET THE ALARM TO GIVE A 25 SECOND TOTAL CLOSURE PULSE. IF YOU DO NOT REQUIRE TOTAL CLOSING OR 288/290I2 SET ALARM FOR 3 SECOND PULSE! 970/1 UPGRADE POSSIBLE.
    Make VAUXHALL Model CORSA Year 2001 S.O.E CAT 2 JUN 00 Ref. V9
    Siren Location MOUNT SIREN IN N/S PLENUM CHAMBER.
    Alarm Location
    Harness Entry ROUTE HARNESS THROUGH N/S UNDER BONNET FUSE BOX VIA TRUNKING.
    Chassis Ground HEAVY BROWN WIRE N/S SILL MAIN EARTH POINT.
    Permanent Supply HEAVY RED LOCATED IN IGNITION SWITCH HARNESS.
    Ignition Supply HEAVY BLACK/VIOLET WIRE LOCATED IN N/S SILL HARNESS.
    Starter Immobilisation N/A.
    Indicators BLACK/GREEN AND BLACK/WHITE WIRES LOCATED IN N/S SILL HARNESS.
    Door Switches DRIVER’S DOOR – GREY WIRE, PASSENGER DOOR – GREY WIRE BOTH LOCATED IN N/S SILL HARNESS. TEST!
    Boot/Tailgate Switch BROWN/WHITE WIRE LOCATED IN N/S SILL HARNESS. TEST MORE THAN ONE!
    Bonnet Switch FIT 638L SWITCH.
    Lock RED/YELLOW WIRE LOCATED IN O/S DOOR HARNESS. TEST!
    Unlock RED/BLUE WIRE LOCATED IN O/S DOOR HARNESS. TEST!
    Window Closing Type TOTAL CLOSURE Diagram Number
    SPECIAL NOTES: NO VOLT SENSE. TRANSPONDER IMMOBILISER FITTED AS STANDARD.
    TO INCORPORATE THE DEADLOCKS, FOLLOW DIAGRAM BELOW USING 4/5 PIN RELAY AND SET THE ALARM TO GIVE A 25 SECOND TOTAL CLOSURE PULSE. IF YOU DO NOT REQUIRE TOTAL CLOSING OR 288/290I2 SET ALARM FOR 3 SECOND PULSE! TO UNLOCK ALL PASSENGER DOOR USE THIRD BUTTON BROWN/WHITE WIRE ON 288/29OI2 AND CONNECT TO UNLOCK WIRE ABOVE.
    UPGRADE POSSIBLE.
    ARM – BLACK/BLUE LOCATED IN N/S DOOR HARNESS.
    DISARM - BLACK/YELLOW WIRE LOCATED IN N/S DOOR HARNESS.
    INHIBIT CONNECTION (270) USE NEGATIVE LOCK AND UNLOCK WIRES ABOVE – LOCATE AT REMOTE CDL RELAY AND CUT THESE WIRES AND FIT 1 AMP DIODES IN CIRCUIT (BAND TO DRIVERS DOOR SWITCH) CONNECT INHIBIT WIRES FROM ALARM BETWEEN DIODE AND DOOR SWITCH.
    Make VAUXHALL Model VIVARO 1.9DTI Year 2001 S.O.E NOT LIST AS STANDARD Ref. V10
    Siren Location O/S INNER WING
    Alarm Location
    Harness Entry DRILL HOLE AND FIT GROMMET IN BULKHEAD ABOVE ACCELERATOR PEDAL
    Permanent Supply RED WIRE LOCATED IN IGNITION SWITCH HARNESS
    Ignition Supply YELLOW WIRE LOCATED IN IGNITION SWITCH HARNESS
    Starter Immobilisation TEST!
    Ignition Immobilisation TEST!
    Fuel Pump Immobilisation TEST!
    Indicators VIOLET WIRE (PIN A4) AND BEIGE WIRE (PIN A3) LOCATED IN WHITE SECTION OF WHITE M/PLUG ON O.E. REMOTE UNIT *LOCATED RIGHT OF STEERING COLUMN RIVETED BEHIND DASH PANEL.
    Door Switches GREEN WIRE LOCATED IN GREEN M/PLUG IN O.E. REMOTE UNIT. TEST MORE THAN ONE GREEN!
    Rear Door Switches VIOLET WIRE LOCATED IN GREEN M/PLUG IN O.E. REMOTE UNIT. TEST MORE THAN ONE VIOLET!
    Lock BEIGE WIRE TEST! MAYBE LOCATED AT CDL RELAY BELOW RADIO?
    Unlock GREEN WIRE TEST! MAYBE LOCATED AT CDL RELAY BELOW RADIO?
    Window Closing Type TEST Diagram Number
    O/S/F N/S/F
    O/S/R N/S/R
    SPECIAL NOTES:
    NO VOLT SENSE.
    *REMOVE TOP OF STEERING COLUMN SURROUND AND INSTRUMENT SURROUND TO GAIN ACCESS TO O.E. REMOTE CDL UNIT.
    UPGRADE POSSIBLE – ARM ON DEAD LOCK – WHITE WIRE (PIN A9) DISARM – BEIGE WIRE (PIN A5)
    Mar 2007
    Doncaster
    Thanks Chris! I know it's a laserline, but the instructions help confirm some of the wires I have confirmed.
    It's been a bit difficult working it out as all the instructions I have found are setup to operate the central locking from the alarm. The A850 uses your existing CDL mech, so it only needs an arm/disarm signal from that and does not provide a pulse itself. I'll crack it by jove!!
  1. Installing a car lighter
    By Dane in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2010, 08:32
  2. Installing a sat nav
    By mattyj33 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd September 2009, 10:18
  3. Installing Sat Nav....
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2007, 18:58
  4. Installing 2 items VXR
    By Andyuk911 in forum South East (RO - Scotty80, ARO jaqubek)
    Last Post: 3rd June 2006, 08:03
  5. Toad alarm
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2005, 22:09
mt toad alarm doesnt unlock passenger door
vauxhall vectra boot fuse box orange wire
