Thread: Replacing Centre Console
    Regular Member TonyR999's Avatar
    Cumbria
    Default Replacing Centre Console
    Hi chaps
    In need to replace part of the centre console (see photo)
    Has anybody done this? is it an easy job to do?...i've looked on this site for instructions but cannot find any. Any help much appreciated
    [Ex]Admin Duncan's Avatar
    I haven't replaced it, but I've had it off when doing other stuff.
    You need to work backwards from the rear console removing each bit as you move forwards to then let you get that part off........
    Cumbria
    Hi Duncan
    CRIKEY! looks a tad severe ...are the other bits..ie: rear heater vents/arm rest pretty easy to remove?
    Quote Originally Posted by TonyR999 View Post
    Yep, reasonably major internal surgery! lol
    Yep, pretty much. Just need to be careful with some bits as they need to be 'coaxed' out - particularly the part around the handbrake lever.
    Basically if you start on the rear part, get yourself a plastic spatula/wedge to prise off parts without gouging them. Start by taking off the cover that holds the rear 12V socket, then prise off the rear section that the 12V socket was in. Then you'll have access to the two main Torx bolts that hold the armrest and then it's a natural progression forwards.
    When you do it, let me know if you come stuck anywhere and I'll answer any questions.
    Cumbria
    Brilliant!...thanks for that Mate, it wont be til next Monday as i'm on detached duties in the Outer Hebrides
  1. Centre Console cup holder?
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2011, 21:40
  2. New Centre Console
    By Maverick in forum Non Vectra C/Signum Album
    Last Post: 7th April 2011, 20:38
  3. centre console
    By Tam80 in forum Bodywork & Interior
    Last Post: 19th September 2010, 10:03
  4. Centre Console
    By matt2002 in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2009, 10:36
