Thread: Original sunglass holder rattling
    Mar 2007
    Finland
    confused Original sunglass holder rattling
    I've noticed rattling sound from the area of my sunglass holder. So I'd like to remove the holder without causing any damage to the mounts. I already removed the screws, but the holder didn't drop-off.
    Is there something still holding it?
    Regular Member silverhairedracer's Avatar
    ESSEX
    I reckon you have a bit of loose change in the holder !its for your sunglasses not a piggy bank
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    if you open the holder and if you look inside it on the top then there shud
    be a few screws holding it in place,if you remove them then it shud unclip
    out from the surround,maybe the screws are loose and need tightening up
    try that and let us know wot happens
    Regular Member kgsric's Avatar
    Northants
    give it a little wiggle & it should come out,i had the same problem it was rattling on roof, i put a small peice of paper between them & tightened screws, job done.dont know if it was the screws or the shim that cured it but its gone
    Mar 2007
    Finland
    Thanks for the tips.
    I did get it off, and found out that the plastic base is the source of the rattling. So I will put some armaflex between the roof and the plastic base, hope that helps. Let you know the results.
    Hertfordshire
    What was the reesult as I've got the same problem?
    Mar 2007
    Finland
    It helped a lot, but few odd times I've still noticed the rattle..
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Silly question here but it's not your sunglasses rattling is it? I had the same problem with mine and it turned out to be the glasses themselves
  1. Sunglass holder & map light
    By woodley Vectraman in forum Bodywork & Interior
    Last Post: 31st July 2012, 19:59
  2. Sunglass holder fitment
    By dannycturbo in forum Bodywork & Interior
    Last Post: 1st October 2011, 23:29
  3. Sunglass Holder!!
    By suresh.chohan in forum Styling
    Last Post: 24th March 2011, 13:54
