Results 1 to 10 of 15
Thread: will it fit!!!
    Regular Member j1 wyx's Avatar
    Gosport-Hants
    Red face will it fit!!!
    we have a 2004 sri , will a 2006 sri steering wheel fit!!! it has the scroll up and down controls on it? thanks for any advice
    if the original wheel has buttons instead of scroll wheels then the answer is a no, not under any circumstances....
    the 6 button wheled cars are 1/2 canbus.. the scroll wheeled cars are full canbus.. totally different wiring throughout the car....
    if by some fluke you have a very early 54 plate full canbus car with existing scroll wheels then you will need a new airbag as well as the changed the shape of that too..
    Wheels still look great BTW.....
    Gosport-Hants
    thanks m8 can i change them over (the buttons etc) just a thought
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    the steering wheel off the facelift will fit your pre-facelift but its the
    airbag thats normally the problem as its a different shape on the
    facelift than it is on the pre facelift,unless you have both the wheel and
    airbag off the facelift then you wont have a problem.
    Quote Originally Posted by j1 wyx View Post
    dependant on the airbag wiring, On the internal slip rings, i don't see why not?..you'll be the first to try that i know off..and seeing your B, i think you'll prob find a way to do it as well..
    Nope, the connectors on the car are totally different and the controls are a different size. I looked into this when I was contemplating putting a facelift wheel on my pre-facelift - the controls are what scuppered it.
    http://forum.vectra-c.com/showthread...8993#post88993
    I'm sure someone has done this very thing on here peeps.
    You sure? Fitted the half-canbus controls (six buttons) onto a facelift wheel into a half-canbus car you mean? I can't see how given what I found when I looked at doing it. The connectors in the car are totally different and the six button controls won't physically fit onto a facelift wheel.
    if they have, hats off to them as they would had to mess around with the CanBus wiring and changed connectors.
    I'll see if I can find the thread.
    Found the thread. After reading the thread again, he didn't bother trying to make the buttons work, he just wanted the smaller steering wheel.
    http://www.vectra-c.com/forum/showth...Steering+Wheel
