Thread: Cd70
    May 2007
    Reading
    Default Cd70
    Quick question what is the best bit rate for ripping music before burning onto a CDR? I have been messing around with the rates and have found the CD70 struggles with lower bit rates. Can't find anything in the manual.
    Oct 2006
    Wellingborough
    I'd never go below 128kbps for mp3s, and it may not like VBR. Personally i use 256kbps.
    May 2007
    Reading
    At 128 it does appear to like songs with alot of "B's" in words. What does VBR mean?
    Regular Member um20's Avatar
    Mar 2007
    Doncaster
    Quote Originally Posted by sturgi View Post
    Variable Bit-Rate. Program works out the "optimal" rate for each song. Don't think it's variable throughout the length of an actual track, but when you're encoding an album you will see different rates for the tracks.
    May 2007
    Reading
    Is VBR something I can turn off? Use WMP should I use Real Player?
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    I always use 128kpbs ripped onto CD's using Windows Media Player and have never had a problem playing them on my CDR2005 on my pre-facelift Vectra. Given the average but more than acceptable quality of the standard-fit CD player, there is little point in going above 128 IMO. Bear in mind that my manual and yours probably has a disclaimer saying that CDR's may not always play properly. Also never had a problem playing my 'homemades' on the decent 'separates' CD player I have at home, neither.
    May 2007
    Reading
    I will give Real Player a go without VBR, see if it's better, and yes I have a disclaimer as well.
  1. CD70 and Aux in
    Last Post: 8th January 2013, 13:59
  2. Cd70 please help!!! :)
    By jones5n in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2011, 10:34
  3. Cd70
    By gregc in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2010, 02:32
  4. cd70
    By wstwatson in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2009, 20:51
