Results 1 to 10 of 19
Thread: Noise from Rear
    Regular Member DesignforLife's Avatar
    Lancashire
    Question Noise from Rear
    I hope someone can help with this or has had a similar problem.
    When driving over bumps or uneven ground - My 06 Signum has a creak/ rattle from the rear. It sounds like the tailgate area or similar. It has only developed this recently. I have checked the basics - no loose trim and the spare wheel is all bolted down properly. It sounds like something moves as the body flexes over bumps.
    I have the Elec Sunroof - could this be part of the problem?
    Is my car 'flexing' and creaking from the rear?
    Help - its annoying me!
    Matt
    Wirral / ellesmere port
    10 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    matt
    i hav that same problem,mine sounds like its round the near side rear door
    area but then when someone sits in the back they cant hear it but i can so
    i`m in he same situation but i`m going to nail it sooner or later,if i find
    anything out then i`ll let you know.
    p.s check ya fone as i ave texed you few times but no
    replies
    Regular Member dazza1964's Avatar
    Leeds
    Try the rear seat hinges and release latches.
    I had a similar prob on another car and it was the seat hinges.
    could also be tha tailgate hinges.
    Lancashire
    Thumbs up
    Hi Andy,
    will give you call in a bit.
    Mine creaks - sounds like the tailgate.
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Had the same problem on my old 2.0 DTi.
    Basically, the tailgate rattles. I stuck 2, 3 inch long and 1 inch wide, 1/4 inch thick foam strips on using double sided sticky tape to the rear of the boot, near the edges; one on each side. Just to give that bit of a forced seal for the boot to push against.
    This problem noisey creak did my head in for around a year before I finally sorted it.
    Hope this helps.
    Lancashire
    Thumbs up
    Hi Ghostrider,
    That is great advice.
    Though I am hoping Vaux will be able to sort it out under Warranty - after all the car is 10months old - surely they can engineer a fix - without having to resort to fitting foam....
    Will see after a visit tomorrow to Vaux for the 20K Service.
    Matt
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    Have you tried untwisting the little buffers on the bootlid to make the shut tighter?
    Lancashire
    Thanks Vid,
    will try that - but again - not exactly sure if it is the bootlid....
    Creaking/ rattling sound is def N/S area could be the rear door or the tailgate though. It might even be the rear seat?
    Anyway Vaux can have a look.
    Cheers - matt
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    My Signum use to crack and rattle from the O/S rear - Vauxhall were convinced it was the roof panels flexing and a field teccy and a chassis bloke from Luton said it was - welding and resin didn't work and in the end they said they had no fix so the dealer gave a full refund trade-in on the Veccy i have now
    Have to add that this was on a 3yr old car......
    Ex-Staff Full Member Spelly's Avatar
    Derbyshire
    http://forum.vectra-c.com/showthread.php?t=24532
    Try this fella, Mine did same and this was the cause..........
  1. Noise from rear
    By stanlee in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2012, 13:07
  2. rear noise
    Last Post: 3rd November 2009, 18:56
  3. rear noise
    By themurf in forum Introduce yourself.
    Last Post: 19th May 2009, 15:45
  4. Rear Noise
    By johnK in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2008, 16:31
  5. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
vectra c boot hinge rattle site:www.vectra-c.com
vectra c boot hinge
