Results 1 to 10 of 18
Thread: Vectra-C Stickers
    Regular Member j13hdb's Avatar
    Nottingham
    Default Vectra-C Stickers
    They've Arrived!!!!!!!!!!!
    After the 3 months quarintine in customs from the LAND OOP NORF my stickers have finally landed on my doorstep!!!
    Thanks to all invoved- if you see me round Notts or anywhere else I'll have a nice cold pint with you
    'Three months in quarantine' - cheeky begger!
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Mine have arrived as well!!
    Feb 2007
    The pool
    Any tips when applying these??
    Remove the backing paper - should come off easily and not lift the letters with it. If it does start to lift the letters then just stop and replace the backing paper and give the sticker a good rub all over. Once you've got the backing paper off then line up on the window and apply one edge first, then smooth the rest of the sticker down and rub over. Then get a credit card and firstly peel off one corner of the adhesive strip. Once you've got the edge lifted up stick the edge of the credit card at the point where the tape is lifting off of the window and continue to pull the tape off - you'll be constantly moving the credit card along as you peel off - the idea of this is that this will stop any letters from lifting off the glass as you pull the tape off (it will also flatten the letters nicely on the glass. Keep going until the tape is removed.
    Hope I explained that well enough.
    Regular Member shan's Avatar
    I dont know if mine are behind the door. I'm still in America. I will see when i'm home on saturday, maybe try and put them on if i have a minute.
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    got mine today, will be fittin them asap.
    Thanks to all
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Found mine behind the door today.
    And Fitted!
    Regular Member kgsric's Avatar
    Northants
    fitted!!
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Done with edit!
  1. Vectra.com stickers
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2011, 17:53
  2. vectra-c.com stickers......
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2009, 21:46
  3. Vectra-C.com Stickers
    By parsco in forum Styling
    Last Post: 24th September 2008, 19:20
  4. Vectra-c.com stickers
    By aaruck in forum Styling
    Last Post: 12th July 2008, 16:03
  5. Where do you put your Vectra-C.com Stickers??
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2007, 22:17
