Thread: car with spanner
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default car with spanner
    hope someone can help! everytime i switch the ignition on i get a yellow light with a picture of a car with a spanner through it but when i start the engine its fine no sign of light! i came home today locked it left it a bit then tried again and did exactly the same thing! hope someone can help please?????
    it means the car has had a minor fault in the last 25 restarts.. but not one that needs immediate attention at VX..
    if it was a 'live' fault the light would stay on permanently..
    to get the car back to normal you could do an ECU reset by disconnecting the battery for 15 mins to reset it bck to the factory defaults.
    Feb 2007
    thanks very much will try that!!!
    Feb 2007
    thanks very much that did the trick!!!!!!!!!!!
    Regular Member lee_eardley's Avatar
    Back to waddington,Lincoln)
    that is what i get on mine, and the explanation would be about right, as i turned my tuning box up the other day and the light stayed on perm. then turned back down....
    not done a reset since
    thanks for the info
    Feb 2007
    i put an induction kit on it yesterday not sure if its linked but pretty sure it is!!!!!!!!
    it may have temporarily affected the MAF sensor readings until it adjusted..all minor problems really..
    Feb 2007
    did the reset last sunday and guess what it returned again yesterday! it does the same thing the car with the spanner goes off as soon as i start the car and i dont see it again until i switch ignition on when i start it again help!!!!!!!!!!!!!
  1. Help - Spanner, then no spanner!
    By Ricksh in forum Engine & Drivetrain
    Last Post: 1st October 2012, 12:04
  2. Spanner
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2010, 20:09
  3. car with spanner going through it?
    By monty2000 in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2010, 13:00
  4. My spanner is always on.....??
    By smiley-sri in forum Engine & Drivetrain
    Last Post: 1st October 2009, 18:54
  5. Oil can with spanner
    By Darryl2.2DTI in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2009, 01:14
