Results 1 to 10 of 11
Thread: rear passenger susp noise
    Regular Member hagga's Avatar
    kingswinford
    Default rear passenger susp noise
    ****** car!!! lol getting a squeaking and knocking from the back pass side suspenion, noise is regardless of speed or road condition..noise dosn't change/stop under braking but does stop when turning right (when susp is loaded up a little). I have jacked up the backend and had a nosey...everything appears ok (after doing this noise dissapeared for 2 days/300 miles but is now back) any ideas peeps..
    spring seating isolating rubber or a worn out damper..
    kingswinford
    cheers...would i be right in thinking that this isolating rubber is sitting on the top of the strut?...and is it a major job?
    it's on the top and bottom of the spring, check for wear and tear, also check for play in the antirollbar links..if it's the damper you should see the outside is a little wet like this one..
    kingswinford
    cheers for that...will strip it down the weekend..if the weathers good
    kingswinford
    Its the lower spring seat..gonna sort these the week end(both sides)..whats the easiest way to remove the springs to replace the seats and are the any oddball sockets that i'll need
    just some torx sockets and an 18mm spanner..an axle stand and a trolley jack..the rest is easy..
    jack and support the car on the stand, then move the jack to under the lower alloy arm and put it below the spring..
    then undo and remove the crossbolt where the arm meets the hub..drive the bolt out, then just slowly lower the jack.. that will let the spring down and out unclamped..if you need more room, just push the arm down lower, but the spring and it's seats will just come out now,,..
    kingswinford
    cheers for that matey...gotta sort it as the sqeak is now a loud creak..and it's doing my head in lol..do you know what size torx..I:ll grab some from work as my electrician sized ones are prob too small
    Regular Member jalooije's Avatar
    Arnhem - The Netherlands -
    Also sounds as a wheel bearing that's wearing down.....
    kingswinford
    Quote Originally Posted by jalooije View Post
    bearings deffo okay..and the creak is present if u bounce the back end while its stationary
  1. clicking type noise from passenger side front
    By jonsyb in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd May 2012, 21:34
  2. Signum rear susp. creaks
    By dariousa in forum Suspension, Wheels & Brakes
    Last Post: 23rd July 2011, 15:33
  3. ticking noise near passenger side dash!!
    By Niks in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2009, 10:12
  4. Knocking/Banging from rear susp
    By coppjoe in forum Suspension, Wheels & Brakes
    Last Post: 10th February 2008, 14:48
  5. Clicking Noise from Behind Passenger airbag?
    By perker in forum Engine & Drivetrain
    Last Post: 4th August 2007, 15:01
