Results 1 to 10 of 13
Thread: Help please. is it my engine?
    Regular Member Teza's Avatar
    Feb 2006
    west midlands
    Default Help please. is it my engine?
    been out & about in the car (2.2 dti) & when I went to start there was this clanking noise like something grinded.
    So gets out has a look under the bonnet. seemed very hot but put it down to the weather with the sun on the bonnet.
    Trys again to start the car. this time she starts fine, 1min down the road the battery light comes on & the display comes up with a car & spanner picture, then starts over heating the temperture light comes on .
    Any ideas ??????????
    Regular Member Islander's Avatar
    Barrow-in-Furness
    How's the water pump ?
    Jul 2006
    Mexico
    Make shure you have the right level of engine oil and coolant, and make shure not to drive if it`s exceding the normal temp....this will ruin you engine mate.
    Feb 2006
    west midlands
    Quote Originally Posted by Islander View Post
    not sure i think thats working.
    Feb 2006
    west midlands
    Quote Originally Posted by BlueRob View Post
    I had a look at the coolant & its ok. will check my oil in a min.
    The temp went well in the red. think i will have to go to the dealers
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Fan belt has snapped for definate and possibly the fan belt pully has shattered. Have a look and see if you can see a V grooved belt on the LHS of the engine, if not, it's the belt.
    Same thing happened on my old car. cost £225 to repair, but have AA repair insurance, so cost £25.
    P.S. If it is the Belt or Pulley ------- DO NOT START OR DRIVE THE CAR
    Feb 2006
    west midlands
    Quote Originally Posted by ghostrider View Post
    Was just looking under the bonnet.
    you hit it right on the nail mate.
    The belt has come off & one of the wheels has come off !
    Gonna cost a bit now then.
    thanks m8
    On another planet
    Engine : 2.0
    Always happy to help if i can, and give something back to vectra-c for all the help it has given me.
    Shame about the belt though, but it is quite common.
    hope you get it fixed soon......and hopefully not to expensively
    yep, have to agree.. the failure of the crankshaft pulley is VERY common on DTi's it appears.. you're the 2nd guy on here to have one fail in 2 days..
    If it was a peugeot HDi then you'd be changing it with every cambelt....
    the pulley normally delaminates and the outer section falls off....
    Nicking Ya Dinner.
    Hold The Press !!!
    I had something similar on my B, it might be the tensioner, that's what happened with mine the bolt worked out and the belt came off, before you go to the garage have a quick look between the cover and the chassis and see if all looks ok there 1st.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
