Results 1 to 3 of 3
Thread: Clutch options - 2.2 SRi
    Gloucestershire
    Default Clutch options - 2.2 SRi
    The clutch on my 52 plate, 78k, has been slipping for a while now, so I could probably do with getting it replaced. Any views on the options available?Clearly vx will be the most expensive option, but are there any good (ie resaonable) aftermarket clutches out there? What is the labout time to replace a clutch? FDo you usually need to replace the flywheel?Any info appreciated.
    Gloucestershire
    bump. Any thoughts?
    LUK make clutches for the aftermarket, so a trip to a good motor factors ( NOT halfords etc) will usually tell you if a pattern is avaliable..then the option is yours, self fit at home, take it to somewhere like 'Mr clutch' (beware of cowboys) or stump it up and just get VX to do the job.. dependant on it's condition ,the flywheel may or may not need replacing/re surfacing..only when the gearbox is off will anyone be able to tell you..
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. options please
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2011, 12:42
  4. 3.2 clutch slipping so being replaced, flywheel options?
    By merge in forum Engine & Drivetrain
    Last Post: 28th May 2011, 16:20
  5. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
