Thread: Headlight Scratched
    Regular Member dave_taiho's Avatar
    Apr 2006
    N Ireland
    Default Headlight Scratched
    While parked yesterday someone decided to collide with my 06 veccie and drive off leaving me with a fist sized dent in the drivers wing and a scuffed bumper and headlight. I was not amused.
    G4 cutting compound took the worst of marks off the bumper and wing and I tried it on the headlight and it took away the light scratching leaving me with several deeper scores.
    The wing and bumper are getting repaired on Tue, but I need a suggestion on a good way to repair the head light as it is a xenon unit and I cannot face the thought or cost of replacing it at the moment.
    Dave
    Regular Member 111's Avatar
    Stockton-on-Tees
    You could try sanding in with a high grade emery paper (1200 or higher) lubricated with washing up liquid & water then polish it with brasso this worked a treat on the light chips I had on mine (caused by 101k miles). try a little bit of the scrach first to make sure you get the required result.
    Regular Member dazzer t's Avatar
    stoke on trent
    you can buy stuff from caravan shops for removing scratches on plastic not sure what its called but it might be worth a go.
    Stockton-on-Tees
    I've seen it but its more or less the same thing as brasso, we nearly got some for our caravan untill we saw the price & read about brasso on the caravan forums, The emery paper will make the scrach the same level as the rest of the cover, Then the brasso is a very fine polish to get rid of the emery marks.
    Regular Member fellie's Avatar
    Lincoln
    remember to mask the paintwork off, or remove the unit first :
  1. scratched disc's
    By markj23 in forum Games Room
    Last Post: 19th February 2011, 23:29
  2. Scratched screen
    By Adam23 in forum Insignia Chat (READ ONLY)
    Last Post: 7th October 2010, 18:52
  3. Scratched
    By Atomic in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2009, 22:26
  4. blastards, scratched my car
    By craigbarlow18 in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2008, 21:42
  5. Scratched my car!
    By lborob17 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2005, 22:26
