Thread: Interesting warning light!!!
    Regular Member mickeyc's Avatar
    Over there between the land and the sky!
    Default Interesting warning light!!!
    I keep getting a warning light come up that looks like the one you get when a bulb has gone, but with an exclamation mark "!" in the middle and I can't seem to find it in the manual, anyone any suggestions? It comes up intermittantly.
    Regular Member j13hdb's Avatar
    Nottingham
    Is it when you press the brake?
    That was my first thought so I got a friend to press the pedal with the engine running and the brake lights seem fine. It seems to come on more randomly than that and for longer periods the further you drive.
    It's the bulb replacement symbol - it should tell you what bulb in the display above the stereo (assuming you've got the graphical display and not just the three line job)
    The randomness could be due to a bulb on it's way out or dodgy/dirty connection.
    Unfortunately I have a simple SXi with no graphical display. What should I do, just wait for something to go pop?
    If you can't see any current failure, then I suppose all you can do is wait for something to go. What you could do though is go around each bulb, remove it and give the contacts on the bulb and socket a clean (check for any oxidisation etc.). That may sort out any issue.
    May 2007
    Grays Essex
    next time it comes on check your center brake light is working,i had the same problem it turned out to be the printed circuit board that had a hairline crack in the circuit board solder!
  1. EGR warning light
    By northantswrx in forum Engine & Drivetrain
    Last Post: 29th April 2012, 21:29
  2. warning light
    By nicj in forum Vectra C / Signum Troubleshooting
    Last Post: 8th December 2011, 00:31
  3. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
vectra bulb replacement light coming on randomly
