Results 1 to 10 of 19
Thread: Front knocking noise over speed bumps
    Regular Member korlinski's Avatar
    South
    Default Front knocking noise over speed bumps
    I have a vectra 3.2 v6. Noticed today that when i go over speed bumps get a knocking from passenger side.
    I have recently had my gear box and radiator replaced (auto gear box fault)
    Could they have not fitted something correctly? or is this something else like anti-roll bar linkage's etc.
    Full Member VectraMat's Avatar
    Hull
    I got this in my facelift SRi, its only from going over speed bumps and the occasional bump in the road. its going in for a service soon so ill get them to sort it then, would be nice to know what it was though so i can give them a clue!
    VXR Gone - Now in BMW 320cd M Sport Convertible
    South
    Does any one know if this is safe to drive?
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Is it a knock or a twang???
    Have a look in here http://forum.vectra-c.com/forumdisplay.php?f=14
    Theres a couple of things it could be:
    Dodgy Spring.
    Spring moving in its seat.
    knackered bushes.
    Only the Dodgy Spring should be dangerous.
    Best to get it checked out though.
    Regular Member R-man's Avatar
    Beds
    I think it'll be another case of the anti roll bar mounts - which by all accounts are getting replaced under warranty. Do a search on this and you should find a few threads on this subject.
    South
    Quote Originally Posted by R-man View Post
    Hope so. It sounds not a loud knocking, and its defo not a twang.
    I am having it MOTed on saturday so WIll the car be safe to drive till then? (going to Manchester today 400 mile round trip)
    South
    Is there any easy way to check?
    I have had a look behind the passenger tyre, couldnt see anything.
    What/where should I look for, for the antiroll bar mounts?
    or spring problems? the springs looked fine. Nothing snapped.
    Beds
    I'm in no way qualified on this sort of stuff, but mine have been crunching over humps for ages and I haven't sorted it, nor have I died and I cover 250 ish miles a week normally. Like I say, I think you'll find that is what it is, it seems very common now, but only a garage can confirm for you.
    Regular Member Majorlook's Avatar
    Leicester
    Hi i had same problem it was a broken coil spring got it fixed under warranty but asked and it would have cost about £100 to fix.
    South East
    I get bang twang and more @ times (not often). Its had the mod done, suspension has been off/on again since and done another 15K. Passed MOT and serivce with no mention.
    You should be fine but dont hold anyone to it.
  1. Weird noise coming from front over speed bumps, Like rubber twisting
    By Cookstar in forum Suspension, Wheels & Brakes
    Last Post: 23rd December 2012, 17:13
  2. knocking noise, over speed bumps ????
    By sthomson1 in forum Suspension, Wheels & Brakes
    Last Post: 18th January 2011, 21:14
  3. Noise over speed bumps
    By scooby8272 in forum Suspension, Wheels & Brakes
    Last Post: 1st October 2010, 13:32
  4. I hear knocking noise going over bumps
    By zazaszazas in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2009, 23:43
  5. Noise over speed bumps
    By spatch in forum Suspension, Wheels & Brakes
    Last Post: 20th December 2008, 21:49
vectra c knocking noise from front
https:www.vectra-c.comforumshowthread.php24990-Front-knocking-noise-over-speed-bumps
vectra c rattiling noise bumps
vectra c weird knock
vectra c front knock turning left iver bump
vectra c front end knock
insignia suspension noise
knocking noise in front suspension corsa utility
vectra c makes a clunking noise when going over bumps
vauxhall insignia knocking noise over bumps
knocking when going over bumps in vauxhall corsa se
opel corsa utility knocking noise over speed bump South Africa
insignia metallic noise over bumps
knocking noise when going over speed bumps
vauxhall vectra loud bang passenger side over bumps
corsa 2014 knocking noise when going over speed bumps
vectra c making noise from front when over 30
vectra c sri noise when i go over bumps
occasional knocking at the front of my vauxhall vectra
vauxhall vectra knocking noise from front
vectra bangung nosie when i go over bumps
vectra c front knocking noise
bumping on front of signum
vauxhall vectra knocking noise from front when go over a bump
