Thread: fog light loom question
    Regular Member nph1's Avatar
    cheltenham/gloucestershire
    confused fog light loom question
    hi all these fog lights are going to be the death of me soon on this ls model . i have followed the thread armour farmer put on here on the how to page, great fine got the fogs, got the rocker switch, got the fog wireing kit but need the front fog light loom how hard could this be rang vauxhall they have quoted me £45 plus vat is this right ? trying to do this on a shoe string but feal im climbing a mountian please advise is this the correct price or do you know some one that can help me find a cheaper fog light loom please ???????
    Regular Member danlat1415's Avatar
    Lancashire
    Why don't you make your own?
    It's only a case of connecting the 2 points on the back of the foglight, to the 2 wires.
    Just get 2 connectors and put them on end of each wire, then it will connect together. Cost 99p approx.
    Any trouble, let me know and I'll get pictures for you.
    (Sorry for jumping the gun, but when you say loom, do you mean the connection part that plugs into the back of each foglight?)
    mmmm intresting please send pics anything at this stage will help
    Lancashire
    Got a couple of pics, hope this helps.
    As you can see in this picture, the back of the fog light has a 2 pin connection, which the loom goes into. (center of picture)
    This is the loom connector that goes into the back of the fog light. Note that it only has 2 wires going to it. It is simply a way of connecting the 2 wires to the back of the fog light.
    Here are the female connectors of the loom itself.
    Right, now you know what the loom looks like, and what it does, you should be able to make your own.
    You need to connect the 2 wires (loom missing) to the back of the fog light.
    You can do this many ways.
    1) take the fog light out, and solder 2 individual wires the the 2 pins on the connector. The just join up the 2 wires coming from the fog light the the 2 wires on the car.
    2) You can try get hold of something like that, that should connect up to the pins in the fog light, and then you can just connect up the wires from the fog light to the wires on the car.
    http://cgi.ebay.co.uk/JST-BEC-Type-M...QQcmdZViewItem
    3) try and cut the loom off a damaged Vectra.
    Hope this helps.
    Dan
  1. roof loom wiring question??
    By Big Red in forum Electrical & ICE (including SatNav)
    Last Post: 2nd November 2012, 23:04
  2. UHP4 bluetooth loom question
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2012, 20:15
  3. Vectra wiring loom question
    By pompey-pimp in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2012, 20:25
  4. Door loom question
    By Keithy in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2010, 21:43
