Thread: resetting the ecu
    Regular Member lee_eardley's Avatar
    Back to waddington,Lincoln)
    Default resetting the ecu
    just a quick question??
    when resetting the ecu will i have to put the code back into the radio ???
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    depends on the year.. cant remember when they went from radio codes to having it tech2'd instead.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    does your car's id card have a different stereo code to its immoboliser code, cos if so then yes, if they are the same then no
    Midlands Mod Shop - NFFC.
    i`ve managed to reset te ecu, and all that happened the radio lost the presets, but nothing else , ehiih is good, ohh and the milesage on the trip cmputer..
    Only question is the RANGE now on the compter is only registering 415 miles, i have checked the setting so english and uk measurements
    Will this figure become more accurate when i have covered a few miles as before when i filled up it would register 600 ????
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Should do mate. Best thing to do is reset the computer after filling up.
    Feb 2006
    Dorset
    When i reset mine after fitting the tuning box and K&N i ragged the nuts off it for a good 200 miles to teach the ECU my driving style is off or on .....
    Aug 2007
    Bath
    I have asked this question in the tuning section but need some help so I am asking here as well as I am getting pretty desperate
    I have been trying to get a tuning module to work on my 1.9 CDTI 120 Siggy but kept getting and engine management light.
    At first this was after a few hundred miles. I would disconect the box (usually burning myself in the process) and then have to suffer numerous restarts before the light would stay out.
    This was before I found this site and found out about resetting the ECU.
    The big question is: Does resetting the ECU by disconnecting the battery wipe the ECU memory completely - I am now getting the spanner light after just a few miles.
    Is this because the ECU is remembering things or should I be looking for something else??
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    From what I understand, disconnecting the battery for 20 mins or longer does the trick as far as the ECU remembering whats stored on there as far as faults go ( not 100% sure, but I "think" thats correct ).
    Been having hassles with my 3.0V6 CDTi lately, used to get the spanner light on the centre display with my CRD2 tuning box fitted and switching off and restarting a few times usually cured it.
    But now I'm getting the exhaust emissions warning light on the dash every few days which requires the battery to be disconnected for a bit, then it resets and goes back to working fine.
    I should say, that its still doing this even though I have removed the CRD2, so it probably wasnt the tuning box in the first place, not sure.
    Have kept it off for now as its going into the Stealers this week to get checked out.
    Vehicle : SRi
    Mileage : 137000
    It should wipe all fault codes stored on the ECU. To get your windows working properly just put them down and then up but keep your finger on up for a few seconds when they get to the top.
    Aug 2007
    Bath
    Took it into the local VX dealers in Chippenham. They had a quick look for me and found a fault code.
    However they told me that disconnecting the battery does not clear any fault codes. These have to be reset using a Tech 2.
    Is there a VX mechanic out there who can confirm this?
  1. what does resetting the ecu do
    By justin32 in forum Engine & Drivetrain
    Last Post: 6th January 2013, 23:12
  2. key fob resetting
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2012, 20:48
  3. Abs resetting
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2012, 12:05
  4. Resetting the ECU
    By kamar in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2010, 12:49
  5. Resetting the ECU
    By wstwatson in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 00:59
