Thread: Grounding a car battery
    Regular Member Merick's Avatar
    Mar 2007
    Wigan & Preston
    Default Grounding a car battery
    Evening,
    I've got an old car battery that i want to use to charge a model helicopter, what would be the best thing to ground it to? The only thing i can find is a pair of ladders!!
    Does it even need grounding or can i just hook the ground of the charger to the ground terminal of the battery?
    Cheers.
    Mark
    Nicking Ya Dinner.
    Best check the voltages 1st, you could ground it to the car engine, as Vx tells you to do this when jumping a flat battery.
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    You can just put the negative of the charger to the battery that will be no problem at all!!
    Mar 2007
    Wigan & Preston
    Just to clarify.. the old battery isn't connected to a car.. it's from an old car and it's sat in the shed.. my nephew has a model helicopter that came with a ciggy lighter charger and no mains charger but i don't want to keep starting the car up to charge his battery for him.. i wondered how i'd go about using the old battery to charge the helicopter instead...
    Does the same apply, just stick the charger on the battery terminals and don't bother grounding the battery?
    Jul 2006
    Colchester
    Quote Originally Posted by Merick View Post
    That will be fine
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Don't understand why you want or need to ground the battery for? It's only 12 V DC,
    May 2007
    Grays Essex
    firstly,if your spare battery has been left flat over winter,there is a very good chance that it wont take a charge anyway if that is the case then throw it away,
    secondly the "ciggy" charger that came with the model helicopter is meant to charge a model helicopter and not a car battery,i hope you havent tried to charge the car battery with this cos you will damage/cook
    it, use a proper car charger for the car battery
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Why not get one of these - then you won't need a car battery at all
    Mar 2007
    Wigan & Preston
    I'm trying to charge the helicopter without having to keep starting the car up. Not charge the battery with the charger!! lol
    I wasn't sure if it needed grounding or not hence the question, now i know it doesn't need grounding.. i'll use it.
    The battery was full when i took it out, i swapped it thinking it was lacking power as the whole dash dimmed far too much when i turned the stereo on but a new battery did the same thing. Whether the old battery has held it's charge or not.. only one way to find out!
    I bought that exact device from maplins in warrington on Saturday but it's died already.. only used it once! lol Taking it back when i get the chance.
    Thanks all.
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  3. Grounding for HID Ballast?
    By the-converter in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2011, 10:57
  4. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
  5. Could I need a new battery?
    By Adz86 in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2009, 06:48
